  3. Device parameters not netlisting in LVS
  • Views 14565
analogmatch
analogmatch over 8 years ago
I am trying to netlist device parameters in LVS. I am using the standard measureParameter and nameParameter command. But the parameters are not getting netlisted. This is usually a simple operation and I've never had an issue with it. What could I be doing wrong that the parameter netlisting is failing? Should I look at something in the CDF setup? What other reasons might cause parameters fail to netlist?
