  3. Voltus-FI: How to automate the creation of selfheating-aware...
  • Replies 29
  • Views 19763
Voltus-FI: How to automate the creation of selfheating-aware EM/IR text reports after every run
hchan
hchan over 8 years ago
After an EM/IR run completes, the menu item: results > EM/IR Data > Report can generate non-selfheating-aware EM/IR text reports.
To get selfheating-aware EM/IR text reports, we open the viewer from EM/IR Data > Layout analysis...  let it load, and then type commands such as
print_em_report -net all_nets -type avg_sh -filename ./avg_sh.txt
at the Voltus-FI console.
Are there other ways create the selfheating-aware EM/IR text reports after a run? (Or a way to pass commands to an active VFI session from CIW, so a SKILL function can be used)
Here are things we have tried:
- An additional license is needed if we start a batch mode process. We have limited number of licenses.
- In Voltus-FI XL user guide, Table 4-1  Supported EMIR Control File Options listed that print_em_report=[...] can be used with emirutil in a control file. We tried adding
emirutil print_em_report=[net=all_nets type=avg_sh filename=avg_sh.txt]
to the prerun emir.conf, and to the viewer .conf file, but text reports were not created in both cases.
Henry
  • hchan
    hchan over 8 years ago in reply to hchan
    Hi Saloni,
    Our "mmsim17" is actually Spectre v17. Would you mind let us know since which Spectre version has this bug been resolved? We would look into installing this or newer version.
    Henry
  • Saloni Chhabra
    Saloni Chhabra over 8 years ago in reply to hchan
    Hi Henry,
    It isn't a known bug and I know a lot of our customers are running the flow the way you want to, but this is the first time I've heard of the issue. This is why I suspected an older Spectre version to be the reason. But if you see the same problem with Spectre171 as well, then the issue is somewhere else. Have you tried running the simulation on a different machine, or a different testcase?
    Saloni
  • hchan
    hchan over 8 years ago in reply to Saloni Chhabra
    Hi Saloni,
    I tried running on various remote machines and locally, with 3 testcases, and got similar behavior. I also experimented to replace emirreport with a shell script that delays the call until .xml files are written, with an ample 5min timeout, and it ended in the timeout. So clearly, the emirreport call is not a spun-off process, but part of the post-simulation flow.
    It seems that indeed there is an ordering problem internally, the xml files generation step starts only after the emirreport call returns. Would you be able to confirm this, or there are other users not having this issue?
    Henry
  • Saloni Chhabra
    Hi Henry,
    I don't see the ordering problem, so if it's a bug, then we'll need to determine what's triggering it. I just ran the SHE flow now to test Spectre 171 ISR2, and I can see in the log a message confirming that *.xml file has been generated right after which emirreport is called. These messages show the timestamps too.
    Initial condition solution time: CPU = 3 ms, elapsed = 3.13997 ms.
    Intrinsic tran analysis time:    CPU = 46.993 ms, elapsed = 55.31 ms.
    TMI results xml file .../results/maestro/Interactive.3/3/testLib:metal_res_sim:1/netlist/input.tmideg0.xml generated at Mon Jun  4 03:42:11 2018
            Time window lookup file of EMIR binary files '../psf//input.bin_time_window' is generated.
    Calling emirreport at Mon Jun  4 03:42:11 2018
    Can you check what your Spectre log says?
    Saloni
  • hchan
    Hi Saloni,
    Thanks for the information. In my spectre log, I don't have the line "TMI results xml file ..." before:
    Spectre (R) Circuit Simulator
    Version 17.1.0.160.isr2 64bit
    Initial condition solution time: CPU = 34.8797 s, elapsed = 17.675 s.
    Intrinsic tran analysis time:    CPU = 3.58198 ks, elapsed = 404.355 s.
    Calling emirreport at Mon Jun  4 08:12:54 2018
    Creating EMIR report
    Warning from spectre during transient analysis `tran'.
        WARNING (EMIR-2603): Failed to run command line: '/tools/cds/ICADV12.30.isr15.lnx86/bin/emirreport [...]. Can not generate EMIR report with emirreport.
    Opening the PSFASCII file ../psf/subckts.info.subckts ...
    TMI results xml file /work/ms_scratch_kel/hchan/simulation/my_sandbox_emshe/tb_clkgen_half_slice_fo1_emsheshe/maestro_hch/results/maestro/Interactive.85/1/my_sandbox_emshe:tb_clkgen_half_slice_fo1_emsheshe:1/netlist/input.tmideg0.xml generated at Mon Jun  4 08:14:26 2018
    Do you know what settings did I miss?
    In Simulation > Reliability > Setup,  TMI analysis mode is enabled. Simulator mode: Spectre native, Enabled self-heating, Enable aging, Aging type: TMI Aging.
    In emir.conf, selfheating options are specified:
    net name=[IDUT.*] analysis=[vmax vavg iavg irms selfheating]
    emirutil shEMEffect=[beolT]
    emirutil cds.lib=/proj/ms_kel/hchan/16n/cds.lib
    emirutil view=[lib=my_sandbox_emshe cell=clkgen_half_slice_fo1 view=layout]
    emirutil shXMLFile=/work/ms_scratch_kel/hchan/simulation/my_sandbox_emshe/tb_clkgen_half_slice_fo1_emsheshe/maestro_hch/results/maestro/Interactive.84/1/my_sandbox_emshe:tb_clkgen_half_slice_fo1_emsheshe:1/netlist/input.dtemp0.xml
    emirutil qrc_output=[runDir=/home/hchan/pmcVeriPhy/my_sandbox_emshe/clkgen_half_slice_fo1/EXT_QRC/RCC_SPICE/tmp runName=clkgen_half_slice_fo1]
    emirutil shParamFile=/home/liblib/16n/techdata/v1_0_beta/voltus_Fi/param.sh
    emirutil techfile=/home/liblib/16n/techdata/v1_0_beta/voltus_Fi/qrcTechFile
    emirutil print_em_report=[net=all_nets type=acrms_sh filename=acrms_sh.txt]
    emirutil print_thermal_report=[type=metal filename=thermal.txt]
    emirutil coupledSH=true
  • hchan
    By any chance the simulation results in psfascii format would delay the writing of the XML file? In the spectre log, after emirreport call, I have a series of messages reading info from psf/ and then write out data files, including the xml file:
    finalTimeOP: writing operating point information to rawfile.
    Opening the PSF file ../psf/finalTimeOP.info ...
    modelParameter: writing model parameter values to rawfile.
    Opening the PSF file ../psf/modelParameter.info ...
    element: writing instance parameter values to rawfile.
    Opening the PSF file ../psf/element.info ...
    outputParameter: writing output parameter values to rawfile.
    Opening the PSF file ../psf/outputParameter.info ...
    designParamVals: writing netlist parameters to rawfile.
    Opening the PSFASCII file ../psf/designParamVals.info ...
    primitives: writing primitives to rawfile.
    Opening the PSFASCII file ../psf/primitives.info.primitives ...
    subckts: writing subcircuits to rawfile.
    TMI results xml file /work/ms_scratch_kel/hchan/simulation/my_sandbox_emshe/tb_clkgen_half_slice_fo1_emsheshe/maestro_hch/results/maestro/Interactive.88/1/my_sandbox_emshe:tb_clkgen_half_slice_fo1_emsheshe:1/netlist/input.tmideg0.xml generated at Mon Jun  4 09:28:09 2018
  • Saloni Chhabra
    Hi Henry,
    Thanks for sharing, I think I understand the problem. You have missed enabling Reliability Analyses from maestro view.
    When running the SHE flow, you should typically see 3 simulations running: fresh, stress and she. Correspondingly, the point numbers in maestro database are 1, 2, 3. Fresh simulation is optional, so the minimum simulations/points you'd get are 2. Out of these simulations, the last one is the SHE run where emirreport should be launched.
    In your log excerpts, I see all messages in point '1' e.g. Interactive.85/1, while the SHE simulation should have been Interactive.2 or .3. This gave me the clue that the setup isn't correct.
    Here's a snapshot of how reliability analysis should be enabled, and how the results will look like. Let me know if this helps.
  • hchan
    HI Saloni,
    Thanks for the detailed information. I enabled TMI in the ADE explorer menu Simulation > Reliability > setup, but indeed didn't enable TMI under Reliability Analysis setup > options > Reliability. I did exactly what your screenshots showed, but the execution order of writing emirreport and then xml file did not change in the SHE run. I tried
    Fresh+Stress+SHE tests
    Fresh+SHE tests
    Fresh Test + stress file input.tmiage0 from prior run + SHE test
    Enable TMI self-heating only
    Enable TMI self-heating and aging
    All tests used Spectre 17.1 isr2, ICADV12.3 isr15, ended with xml file not found, because it was written after the vfi.log finished.
    I noticed that all my runs created the input.dtemp0.xml, not not input.tmiage0.xml file shown in your log.
    Henry
  • Saloni Chhabra
    Hi Henry,
    'input.dtemp0.xml' created in SHE run is read by Voltus-Fi for the analysis, so it seems the file is getting generated for you, but later than expected.
    I'll need to look at your setup environment to be able to assist further as the behaviour you are seeing is indeed bizarre. Can I request you to contact Cadence customer support once again now? If it turns out to be setup issue, we should plug that gap so a user does not run into this problem. Or if it's actually a software issue, then the AE can try to reproduce it internally and help R&D fix it.
    Saloni
