  3. Voltus-FI: How to automate the creation of selfheating-aware...
  • Replies 29
  • Views 19739
Voltus-FI: How to automate the creation of selfheating-aware EM/IR text reports after every run
hchan
hchan over 8 years ago
After an EM/IR run completes, the menu item: results > EM/IR Data > Report can generate non-selfheating-aware EM/IR text reports.
To get selfheating-aware EM/IR text reports, we open the viewer from EM/IR Data > Layout analysis...  let it load, and then type commands such as
print_em_report -net all_nets -type avg_sh -filename ./avg_sh.txt
at the Voltus-FI console.
Are there other ways create the selfheating-aware EM/IR text reports after a run? (Or a way to pass commands to an active VFI session from CIW, so a SKILL function can be used)
Here are things we have tried:
- An additional license is needed if we start a batch mode process. We have limited number of licenses.
- In Voltus-FI XL user guide, Table 4-1  Supported EMIR Control File Options listed that print_em_report=[...] can be used with emirutil in a control file. We tried adding
emirutil print_em_report=[net=all_nets type=avg_sh filename=avg_sh.txt]
to the prerun emir.conf, and to the viewer .conf file, but text reports were not created in both cases.
Henry
  • Saloni Chhabra
    Saloni Chhabra over 8 years ago in reply to hchan
    Hi Henry,
    Can you set the below env var before launching your Spectre run:
    setenv CDS_MMSIM_VOLTUSFI_ROOT  $CDSHOME
    This will call the report generation utility 'emirrerpot' from IC installation instead of Spectre. As text reports generate ok from Voltus-Fi console, let's use the same version in batch-mode too. Some more information here:
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O0V000007MgvlUAC&pageName=ArticleContent&sq=005d0000001T4VEAA0_20185191636205
    Test run 3 appears to be correct if you don't get errors for missing files; it's hard for me to guess the name for runDir and runName without looking at Quantus command file. If in doubt, you can get the settings from Voltus-Fi GUI because you would have entered runName and runDir under QRC Run field.
    Saloni
  • Saloni Chhabra
    Saloni Chhabra over 8 years ago in reply to Saloni Chhabra
    Also, can you tell me your ICADV version? The support for reading 'emirutil cds.lib=' was introduced in ICADV12.3 ISR14 I think, so once you set CDS_MMSIM_VOLTUSFI_ROOT and are using a later version, you shouldn't have to create a soft-link to cds.lib.
  • hchan
    hchan over 8 years ago in reply to Saloni Chhabra
    Hi Saloni,
    The ICADV version in use is ICADV12.30.isr15.lnx86. The QRC runDir in the VFI GUI is /<some_path>/<cellname>/EXT_QRC/RCC_SPICE/ and runName is <cellname>, i.e. they match the setting in 'Test run 1' in my previous message, but causes the _qrc_tech_dir error when used in batch mode or Spectre.
    Regarding the error:  Failed to start QRC module 'shapeServer'. Would you mind telling us a bit more how QRC shapeServer is invoked by emirreport after reading the TMI file? e.g. How is the execution path determined? Our Spectre call is through a wrapper that in turns make a system call. It is possible that the search paths or env vars missed the required data.
  • Saloni Chhabra
    Hi Henry,
    I don't see a reason why the runDir and runName entered in GUI should not work in the batch-mode. The files _qrc_tech_dir and _save_layers should be present in the extraction database.
    Have you re-run the flow after setting the env var CDS_MMSIM_VOLTUSFI_ROOT? Does Voltus-Fi version look different in vfi.log now?
    Regarding QRC shapeserver error, I've seen it occur mostly due to an issue in extraction database, but I am surprised you see this error only when running the flow batch-mode (assuming you have sync'ed the versions now). Do you have the below setting in Quantus CCL?
    output_setup \
    	-keep_temporary_files "true"
    At this stage, it might be worth getting in touch with Cadence customer support so someone can review your setup via a Webex session.
    Saloni
  • hchan
    Hi Saloni,
    Thanks for your help. After getting further support from Cadence support AE, I have the correct setup to get the VFI batch run going after spectre simulation.
    In the Spectre netlist/ directory, I noticed that the self-heating XML files (e.g. input.dtemp0.xml) are always created after the batch mode run started (i.e. vfi.log timestamp ~1min earlier than shXMLFile timestamp). This causes the XML file not found by the batch mode run. Is there a way to fix this, or we suppose to use the XML file from the prior rather than the current run?
  • Saloni Chhabra
    This doesn't sound normal. Can you please let me know the following:
    1. What Spectre version is being used?
    2. What ICADV12 version is being used?
    3. Finally, please paste the contents of vfi.log.
    Saloni
  • hchan
    Certainly. Here are the info:
    Spectre version:  mmsim15.10.isr6
    ICADV12 version:  ICADV12.3 isr15
    VFI version: ICADV12.3 isr15
    vfi.log:
    INFO: Starting Voltus-Fi Batch Mode Application.
    Command run is:
    /tools/cds/ICADV12.30.isr15.lnx86/tools.lnx86/sev/bin/64bit/emirreport -c /work/ms_scratch_kel/hchan/simulation/my_sandbox_ems
    he/tb_clkgen_half_slice_fo1_emsheshe/maestro_hch/results/maestro/Interactive.73/1/my_sandbox_emshe:tb_clkgen_half_slice_fo1_em
    sheshe:1/netlist/emir.conf -db /work/ms_scratch_kel/hchan/simulation/my_sandbox_emshe/tb_clkgen_half_slice_fo1_emsheshe/maestr
    o_hch/results/maestro/Interactive.73/1/my_sandbox_emshe:tb_clkgen_half_slice_fo1_emsheshe:1/netlist/../psf/input.emir0_bin -ou
    tdir /work/ms_scratch_kel/hchan/simulation/my_sandbox_emshe/tb_clkgen_half_slice_fo1_emsheshe/maestro_hch/results/maestro/Inte
    Voltus-Fi version being used is as follows:
     Voltus-Fi batch mode application (64-bit) - High Capacity Power IR/EM - v06.17-e469_1 ((09/17/2017 17:31:56))
     Copyright (c)  Cadence Design Systems, Inc.  1996 - 2014
    INFO: loading MMSIM results
    INFO: loading MMSIM all net results
    Info: Reading Self Heating TMI File: /work/ms_scratch_kel/hchan/simulation/my_sandbox_emshe/tb_clkgen_half_slice_fo1_emsheshe/
    maestro_hch/results/maestro/Interactive.73/1/my_sandbox_emshe:tb_clkgen_half_slice_fo1_emsheshe:1/netlist/input.dtemp0.xml
    FATAL: Unexpected error : Could not open file : /work/ms_scratch_kel/hchan/simulation/my_sandbox_emshe/tb_clkgen_half_slice_fo1_emsheshe/maestro_hch/results/maestro/Interactive.73/1/my_sandbox_emshe:tb_clkgen_half_slice_fo1_emsheshe:1/netlist/input.dtemp0.xml
    Process Info :
      User time          = 0 seconds
      System time        = 0 seconds
      Children user time = 4 seconds
      Children sys time  = 3 seconds
      Virtual mem. size  = 327,905,280 bytes
      Total alloc size   = 0 bytes
      In use alloc size  = 0 bytes
      Page fault w/o IO  = 24,708
      Page fault w/  IO  = 157
      No. of swaps       = 0
      Page size          = 4,096 bytes
      Real Time(HH:MM:SS)= 00:00:24
      Peak Memory Usage  = 100392 kB
    INFO: Ending Voltus-Fi Batch Mode Application.
    netlist > ls -ltr
    total 40374
    -rw-r--r--  1 hchan eng      352 Mar 19 11:15 spectre.sim
    -rw-r--r--  1 hchan eng       29 Mar 19 11:15 spectre.inp
    drwxr-xr-x  2 hchan eng        0 Mar 19 11:15 raw/
    -rw-r--r--  1 hchan eng      176 Mar 19 11:15 control
    drwxr-xr-x  2 hchan eng     1271 Mar 19 11:15 amap/
    -rw-r--r--  1 hchan eng      223 May 30 09:03 netlistHeader
    -rw-r--r--  1 hchan eng        0 May 30 09:03 netlistFooter
    -rw-r--r--  1 hchan eng    38233 May 30 09:03 netlist
    drwxr-xr-x  2 hchan eng       25 May 30 09:03 map/
    drwxr-xr-x 10 hchan eng      257 May 30 09:03 ihnl/
    drwxr-xr-x  2 hchan eng        0 May 30 14:57 statAlters/
    -rw-r--r--  1 hchan eng      524 May 30 14:58 si.env
    -rw-r--r--  1 hchan eng       86 May 30 14:58 si.foregnd.log
    -rw-r--r--  1 hchan eng    39796 May 30 14:58 input.scs
    -rw-r--r--  1 hchan eng     1509 May 30 14:58 emir.conf
    -rwxr-xr-x  1 hchan eng      179 May 30 14:58 runSimulation*
    -rwxr-xr-x  1 hchan eng      607 May 30 14:58 runGenricJob9*
    lrwxrwxrwx  1 hchan eng       30 May 30 14:58 cds.lib -> /proj/ms_kel/hchan/16n/cds.lib
    -rw-r--r--  1 hchan eng  4901040 May 30 15:03 spectre.ic
    -rw-r--r--  1 hchan eng  4806374 May 30 15:09 spectre.fc
    -rw-r--r--  1 hchan eng   261413 May 30 15:10 summary.rpt
    -rw-r--r--  1 hchan eng     3800 May 30 15:10 vfi.log
    -rw-r--r--  1 hchan eng      591 May 30 15:11 input.tmiage0_106096.100021
    -rw-r--r--  1 hchan eng 20290408 May 30 15:11 input.tmiage0_106096.100021.dat
    -rw-r--r--  1 hchan eng  1347085 May 30 15:11 input.dtemp0.xml
    -rw-r--r--  1 hchan eng    63173 May 30 15:11 input.dtemp0
    -rw-r--r--  1 hchan eng       17 May 30 15:11 input.tmiage
  • hchan
    ICADV12  (and Voltus-FI) version: ICADV12.3 isr15
    netlist/ directory and vfi.log file:
  • Saloni Chhabra
    Thanks, it appears to be a bug in MMSIM where it is invoking emirreport before *.xml is available on the disk. Your MMSIM version is very old (more than 2 years), so can you please move to a newer version and check if that solves the issue?
    Going back to the older posts in this thread, I notice you were using Spectre171 at some point, so that will be a good version to try.
    Saloni
  • hchan
    Hi Saloni,
    Thanks for the info.
    I tried mmsim17.10.isr2 and it behaves similarly (could you confirm?). Meanwhile, Spectre171 is not fully setup in our methodology. I'll check with our infrastructure team if it can be enabled.
    Henry
