  3. Plot DNL and INL of DA converter across codes
  • Views 22324
Cotomaznamenat
Cotomaznamenat over 8 years ago
Hi all,
I'm trying to plot a DNL and INL od DAC across all the codes.
I run simple DC sweep simulation and I already have Calculator expressions for DNL and INL.
Now I would like to run MC simulation and calculate standard deviation of every for every DAC output step to see for which input code change the DNL is the worst.
I know it is possible with Matlab (never tried it) but is it also possible with OCEAN script?
Adam
    Andrew Beckett over 8 years ago +1
    If you do a sweep, and then compute the same expression for DNL, you should see a plot of DNL versus the swept variable - or if you're sweeping over more than one thing, you'll get a family of curves,…
    If you do a sweep, and then compute the same expression for DNL, you should see a plot of DNL versus the swept variable - or if you're sweeping over more than one thing, you'll get a family of curves, one for each outer swept variable (with the inner swept variable on the x-axis).
    Sorry not to be more specific, but there wasn't a great deal of information in your post (such as which tool you're using - ADE L, XL, Explorer, Assembler, how you're sweeping things, which versions you're using, and what exactly the expression looks like).
  • Cotomaznamenat
    Cotomaznamenat over 8 years ago in reply to Andrew Beckett
    Sorry for not to be more specific. I use DC sweep of voltage source which is input to ideal AD converter which just generate input code for my DUT : DA converter.
    Tools I use : ADE Explorer
    For LSB, DNL and INL extraction I use the following expression. I would like to extract separately GAIN, OFFSET and DNL/INL error not to mix them together. I'm just trying to do a linear interpolation of the DAC output curve and from it calculate OFFSET, DNL and INL.
    Expressions :
    DAC_OUT=VS("/DAC_OUT")        "output of my DAC (voltage or current) used further in the expressions"
    LSB=average(deriv(DAC_OUT))
    OFFSET=average((DAC_OUT - (xval(DAC_OUT) * LSB)))
    Ideal DEC output for calculation of DNL and INL (with OFFSET and GAIN error)
    IDEAL=((xval(DAC_OUT) * LSB) + OFFSET)
    Absolute end relative (to LSB) DNL error
    DNL_abs=(step_DAC_OUT - LSB)
    DNL_lsb=((step_DAC_OUT - LSB) / LSB)
    Absolute end relative (to LSB) INL error
    INL_abs=(DAC_OUT - IDEAL)
    INL_lsb=((DAC_OUT - IDEAL) / LSB)
    With this expressions I'm able to check the DNL and INL of typical run (which is typically quite good :) Now I would like to run 200 Monte Carlo simulations so I will have 200 waves of DNL and INL with DAC input code on X axis.
    I would like to calculate standard deviation for every DAC code across this 200 waves to be able to see for which DAC input code change the DNL is the worst.
    I have tried to do this with EvalType (corners, sweeps, all) but i didn't succeed. I'm wondering if I could do it with Ocean script.
    Thank you
    Adam
