  3. Importing PSPICE or TI models into Cadence Virtuoso
  • Subscribers 136
  • Views 26741
Raffaele Aaron
Raffaele Aaron over 8 years ago
Hi everyone,
I've started a few months ago working on Cadence Virtuoso 6.1.7 and I've been able to import models using this guide (e.g. this model), unfortunately it doesn't work for some particular .lib files.
In particular I'm trying to import this model file for the THS4521, but, although it's a pspice model, it won't simulate through ADE.
A subset of the errors output by the simulator are as follows:
Fullscreen error.txt Download
Subset of errors found while running ADE
Error found by spectre in `FDA_HT3', during circuit read-in.
    ERROR (SFE-23): "LIB_FOLDER/THS4521/THS4521.LIB" 343: The instance `XI85' is referencing an undefined model or subcircuit, `PARAMS:'. Either include the file containing the definition of `PARAMS:', or define `PARAMS:' before running the simulation.
    ERROR (SFE-23): "LIB_FOLDER/THS4521/THS4521.LIB" 344: The instance `XI56' is referencing an undefined model or subcircuit, `PARAMS:'. Either include the file containing the definition of `PARAMS:', or define `PARAMS:' before running the simulation.
    ERROR (SFE-23): "LIB_FOLDER/THS4521/THS4521.LIB" 349: The instance `XI16' is referencing an undefined model or subcircuit, `PARAMS:'. Either include the file containing the definition of `PARAMS:', or define `PARAMS:' before running the simulation.
    ERROR (SFE-23): "LIB_FOLDER/THS4521/THS4521.LIB" 352: The instance `XI11' is referencing an undefined model or subcircuit, `PARAMS:'. Either include the file containing the definition of `PARAMS:', or define `PARAMS:' before running the simulation.
    ERROR (SFE-23): "LIB_FOLDER/THS4521/THS4521.LIB" 354: The instance `XI60' is referencing an undefined model or subcircuit, `PARAMS:'. Either include the file containing the definition of `PARAMS:', or define `PARAMS:' before running the simulation.
Error found by spectre in `CMFB', during circuit read-in.
    ERROR (SFE-23): "LIB_FOLDER/THS4521/THS4521.LIB" 109: The instance `XI1' is referencing an undefined model or subcircuit, `PARAMS:'. Either include the file containing the definition of `PARAMS:', or define `PARAMS:' before running the simulation.
    ERROR (SFE-23): "LIB_FOLDER/THS4521/THS4521.LIB" 120: The instance `XI5' is referencing an undefined model or subcircuit, `PARAMS:'. Either include the file containing the definition of `PARAMS:', or define `PARAMS:' before running the simulation.
    ERROR (SFE-23): "LIB_FOLDER/THS4521/THS4521.LIB" 362: The instance `XI24' is referencing an undefined model or subcircuit, `PARAMS:'. Either include the file containing the definition of `PARAMS:', or define `PARAMS:' before running the simulation.
    ERROR (SFE-23): "LIB_FOLDER/THS4521/THS4521.LIB" 363: The instance `XI25' is referencing an undefined model or subcircuit, `PARAMS:'. Either include the file containing the definition of `PARAMS:', or define `PARAMS:' before running the simulation.
    ERROR (SFE-23): "LIB_FOLDER/THS4521/THS4521.LIB" 368: The instance `XI40' is referencing an undefined model or subcircuit, `PARAMS:'. Either include the file containing the definition of `PARAMS:', or define `PARAMS:' before running the simulation.
Error found by spectre in `OUTPUTCIR', during circuit read-in.
    ERROR (SFE-23): "LIB_FOLDER/THS4521/THS4521.LIB" 179: The instance `XI25' is referencing an undefined model or subcircuit, `PARAMS:'. Either include the file containing the definition of `PARAMS:', or define `PARAMS:' before running the simulation.
    ERROR (SFE-23): "LIB_FOLDER/THS4521/THS4521.LIB" 180: The instance `XI23' is referencing an undefined model or subcircuit, `PARAMS:'. Either include the file containing the definition of `PARAMS:', or define `PARAMS:' before running the simulation.
    ERROR (SFE-23): "LIB_FOLDER/THS4521/THS4521.LIB" 199: The instance `XIVOL' is referencing an undefined model or subcircuit, `0.085'. Either include the file containing the definition of `0.085', or define `0.085' before running the simulation.
    ERROR (SFE-23): "LIB_FOLDER/THS4521/THS4521.LIB" 202: The instance `XIVOH' is referencing an undefined model or subcircuit, `0.085'. Either include the file containing the definition of `0.085', or define `0.085' before running the simulation.
    ERROR (SFE-23): "LIB_FOLDER/THS4521/THS4521.LIB" 215: The instance `XISOURCEVLIMIT' is referencing an undefined model or subcircuit, `35e-3'. Either include the file containing the definition of `35e-3', or define `35e-3' before running the simulation.
    ERROR (SFE-23): "LIB_FOLDER/THS4521/THS4521.LIB" 218: The instance `XISINKVLIMIT' is referencing an undefined model or subcircuit, `-35e-3'. Either include the file containing the definition of `-35e-3', or define `-35e-3' before running the simulation.
    ERROR (SFE-23): "LIB_FOLDER/THS4521/THS4521.LIB" 233: The instance `XI1' is referencing an undefined model or subcircuit, `PARAMS:'. Either include the file containing the definition of `PARAMS:', or define `PARAMS:' before running the simulation.
ALSO this type of errors:
Warning from spectre in `HPA_AND2':`I194.XI0.XI32.XAHDLI44', in `CMFB':`I194.XI0.XI32', in `FDA_HT3':`I194.XI0', in `THS4521':`I194', during hierarchy flattening.
    WARNING (SFE-29): "LIB_FOLDER/THS4521/THS4521.LIB" 471: Cannot set parameter `v'.
Error found by spectre in `HPA_AND2':`I194.XI0.XI32.XAHDLI44', in `CMFB':`I194.XI0.XI32', in `FDA_HT3':`I194.XI0', in `THS4521':`I194', during hierarchy flattening.
    ERROR (SFE-1997): "LIB_FOLDER/THS4521/THS4521.LIB" 471: I194.XI0.XI32.XAHDLI44.E1: parameter `coeffs': Behavioral expressions can not be assigned to netlist subckt or model parameters, only device instance parameters can use behavioral expressions.
Does anyone have any idea on how to import this model?
Thank you very much in advance,
Raffaele Aaron
    Andrew Beckett over 8 years ago +1
    You should reference the model either via the "PSpice Files" section of the Setup->Simulation Files in ADE or by creating a pspice view and pasting the model in that way (setting the view type as "Pspice…
    You should reference the model either via the "PSpice Files" section of the Setup->Simulation Files in ADE or by creating a pspice view and pasting the model in that way (setting the view type as "Pspice" when creating the new view, and then switching into that view using either the view list or a config). Don't just include it as normal SPICE (because it's not - there's an explicit approach for including pspice models in spectre because they have additional syntax beyond Berkeley SPICE).
  • Raffaele Aaron
    Raffaele Aaron over 8 years ago in reply to Andrew Beckett
    Thank you very much Andrew, it worked!Thumbsup
