  3. Monte Carlo mismatch on selected instances when these instances...
  • Views 15150
Monte Carlo mismatch on selected instances when these instances are defined by (nested) config files
HansB
HansB over 8 years ago
Good morning,
I'm running MC mismatch and want to restrict the mismatch variations to a certain hierarchy defined by a config file.
This config file in itself is again part of another hierarchy defined by another config.
It seems not possible to select the instances for mismatch directly by clicking the config view:
WARNING (ADEXL-1667): The following instances will not be added as DUT because they are not valid subcircuit instances
/iloopfilter/imsde_wbadc_lf_fmdab_loopfilter/ilf_fmdab_st0_top    (msde_wbadc_lf_tb_lib:tb_loopfilter_cmrr_cl:1)
The "specify instances for Monte Carlo" menu allows to select between  "schematic, master, subcircuit, text " but not "config" (?).
How can I do this ?
Am I forced to first create a flat hierarchy?
groet
Hans
