  3. Monte Carlo simulation results have difference even in ideal...
  • Views 15144
Monte Carlo simulation results have difference even in ideal circuits
sam jiang
sam jiang over 8 years ago
Hi everyone,
I'm now running an analog-to-digital converter project, all the circuits are ideal (vcvs built op-amp, switch, quantizers...) to verify the function.
So if I run MC mismatch using ADE-XL for this ideal circuits, every time I got the same waveforms and final Quantizer output code, this is what I expected.
The problem occurs when I started to put some real circuits in the schematic, for example  just an inverter in standard library (the inverter is not connected to anything, just put in the schematic),
and now for MC simulation the results are different,  some nodes' waveforms now start to have slightly difference, but I don't know where those mismatches come from.
    Not really enough information to go on. I can imagine that the fact that you now have some real circuits in the design which are being varied statistically could lead to some differences in the time steps being simulated (which would affect the rest of the circuit), but without more details I don't see how anyone can help you...
    You also didn't ask a question, so not sure what you're hoping to have answered?
