  3. How to plot frequency characteristic of capacitance?
  • Views 22836
kwsgk
kwsgk over 8 years ago
Hi. all.
I'd like to plot frequency characteristic of capacitance in spectre.
In AC simulation, I get current of capacitor (Ic) and its imaginary part ( Im(Ic) ).
Now tring to calculate Cap = Im(Ic) / omega  (omega=2*pi*freq)
I can't find how to devide Im(Ic) by freq or omega.
I find 'xval' can plot simulation frequency, but dividing doesn't work.
Could you help, please?
Best Regards
Kawai
    Hi Kawai,
    I don't see why:
    imag(i("/C1/PLUS"))/(2*3.1415926535*xval(v("/something")))
    (or similar) doesn't work. If you can plot xval then you should be able to divide by it (unless you have 0 in the frequency range?)
    Perhaps you can give the actual expression and the error message.
  • kwsgk
    kwsgk over 8 years ago in reply to Andrew Beckett
    Hi Andrew.
    Thanks a lot for your reply.
    The expression is as folows.
    (imag(IF("/C1/PLUS")) / (2 * 3.14 * xval(IF("/C1/PLUS"))))
    The error message is as follows
    WARNING (OCN-6038): Results ac are not available for /"~~Simulation Path~~"/distributed/job105/psf. Use results() for a list of available results.
    *Error* imag: can't handle imag(nil)
    *Error* xval: can't handle xval(nil)
    *Error* ("times" 0 t nil ("*Error* times: can't handle (6.28 * nil)"))
    ERROR (ADE-1057): Could not evaluate expression
            '(imag(IF("/C1/PLUS")) / (2 * 3.14 * xval(IF("/C1/PLUS"))))'
         because of the following error(s)
         Ensure that the definition of the expression is correct.
    I found that in case of using calculator (post simulation) above expression seems to work. It returns 1e-12 independent to frequency.
    I test xval only "xval(VF("/net01"))" but it doesn't work today.
    Best regards.
    Kawai.
    Andrew Beckett over 8 years ago in reply to kwsgk
    Hi Kawai,
    It sounds as if you're just not looking at the results properly - did you do what it suggests in the error and see what results() returns?
    This is something that would be best handled with a webex with customer support, to be honest. Trying to debug it through the forums is going to be really hard - I can't see any logical explanation as to why it doesn't work...
  • kwsgk
    Hi Andrew.
    I understand above expression works  appropriatly.
    With calculator, frequency charactoristic is plotted.
    As you say, Something is wrong in my operation or recognition.
    I'd like to recheck manuals. Then ask custormer support.
    Thank you very much for your advice and kindness.
    Best regards,
    Kawai.
  • drdanmc
    drdanmc over 8 years ago
    my usual trick is to include a 1pF analogLib capacitor in my test bench and drive with a 1V AC source.  Now I can find the imaginary part of the current in that cap and I have omega*1pF easily available.  Then I don't have to remember xval() or enter pi.
  • kwsgk
    kwsgk over 8 years ago in reply to drdanmc
    Thanks Dan.
    Your trick works. That's a good idea!
