  3. Greyed menu: "Run Assura Quantus QRC..." and "Run Assura...
  • Replies 35
  • Views 30369
Greyed menu: "Run Assura Quantus QRC..." and "Run Assura Quantus QRC..."
manudupouy
manudupouy over 8 years ago
All is in the title. I can not run Quantus QRC because it greyed in QRC menu and don't know why.
Someone can help?
Best regards,
wighou
    Andrew Beckett over 8 years ago in reply to manudupouy
    Thanks - that’s useful evidence as now I can peel another layer off the onion and hopefully figure out the root cause (the QRC menu item is greyed out because of a missing item in the Assura menu; just need to determine why that is missing). Hopefully I’ll be able to look later today.
  • manudupouy
    manudupouy over 8 years ago in reply to Andrew Beckett
    I discovered one more interesting thing.
    There are 3 directories in "<cds_install_path>/EXT181/tools/extraction/bin/64bit": 5.1.0, 6.1.0, 6.1.7
    I deleted 6.1.0 directory. When I did that, QRC menu didn't appear in my layout window.
    So, I think that the problem is that the context menu is loaded from the wrong directory, 6.1.0 instead of 6.1.7.
    I don’t think that’s the reason. I suspect you’ve just disturbed a pre-check by doing this.
    Am I right in thinking that you’ve also opened a case with customer support on this? I want to avoid duplication of work...
  • manudupouy
    The path I put in the previous message was wrong. The directories are in "<cds_install_path>/EXT181/tools/extraction/bin/64bit/etc/context"
    Really Andrew, I think it could be the reason yet, because I made another try. I removed the 6.1.7 directory. And the QRC menu appeared normally. So, the layout editor is loading context menu from 6.1.0 directory instead of 6.1.7.
    I opened a case with customer support but I didn't have any solution until now. And the support don't want to help because I am working on CentOS instead of RedHat. So, this forum is my ultimate hope. My university make an effort to pay Cadence license. CentOS is equivalent to RedHat and always worked fine for us until now.
    wighou
    I'm sure this is nothing to do with CentOS. Also, having checked, the 6.1.0 is always loaded even in my case (the code doesn't appear to load the 6.1.7 directory - so that's not the reason here).
    The reason why the QRC->Run Assura Quantus QRC menu is greyed out is because you don't have Assura->Run Quantus QRC in your menus (it should be between ERC Browser and Close Run).
    I can't really see why this isn't working - I've traced through the code a lot, but the only place I can see where the menu is missing in the Assura menu is when it doesn't find QRC, and because Assura RCX is EOL, it removes the menu item.
    Can you check the return value of each of these:
    getShellEnvVar("QRC_HOME")
    getShellEnvVar("QRC_ENABLE_EXTRACTION")
    then try this:
    tracev(qrcUI_Ok)
    trace(_vuiIsQrcMenuAvailable _vuiIsRcxMenuAvailable)
    before you start the layout editor for the first time in a session, and post the section of the CDS.log (or what you see in the CIW) when you open the layout - there should be some trace messages (I'm assuming that as a University you have the SKILL Development product).
  • manudupouy
    Here are the results (I also tried to enable QRC_ENABLE_EXTRACTION in another session but it didn't work):
    "/opt/cadence/EXT181"
    nil
    tracev(qrcUI_Ok)
    |[1]qrcUI_Ok set to unbound, was unbound
    (qrcUI_Ok)
    *WARNING* Function _vuiIsQrcMenuAvailable not defined
    *WARNING* Function _vuiIsRcxMenuAvailable not defined
    (_vuiIsRcxMenuAvailable _vuiIsQrcMenuAvailable)
    Loading le.cxt
    Loading mpt.cxt
    *INFO* (icLic-302) License Virtuoso_Layout_Suite_GXL ("95321") was used to run Layout L.
    Initializing from libInit.il for library tsmc18...
       --  pcell18v1a.cdn
       --  tsmc18_updateCDFs.ile
       --  tsmc18.cxt
    Loading Working place Display File '/home/bit/workspace/TSMC-CR018/display.drf'
    Loading oasis.cxt
    Loading analog.cxt
    Loading asimenv.cxt
    Loading spectrei.cxt
    Loading devCheck.cxt
    Loading relXpert.cxt
    Loading hspiceD.cxt
    Loading spectreinl.cxt
    Loading msgHandler.cxt
    Loading UltraSim.cxt
    Loading AMSOSS.cxt
    Loading AMS.cxt
    tsmcCdfFormInitCB
    Loading drdEdit.cxt
    Loading soi.cxt
    Loading te.cxt
    Loading schHDL.cxt
    Loading wsp.cxt
    Load shared object file /opt/cadence/ASSURA41/tools.lnx86/assura/lib/64bit/libavview.so
    Version:  @(#)$CDS: libavview.so version av4.1:Production:dfII6.1.7-64b:IC6.1.7-64b.500.12 05/03/18 22:03 (sjfhw625) $
    |[3]qrcUI_Ok set to nil, was unbound
    |[3]qrcUI_Ok set to nil, was nil
    |[3]_vuiIsQrcMenuAvailable(...)
    |[3]_vuiIsQrcMenuAvailable --> ...
    |[3]_vuiIsRcxMenuAvailable(...)
    |[3]_vuiIsRcxMenuAvailable --> ...
    |[2]qrcUI_Ok set to unbound, was nil
    Loading lo.cxt
    Loading vb.cxt
    Loading see.cxt
    Loading oi.cxt
    Loading treeAssistant.cxt
    Loading asst.cxt
    Loading mtv.cxt
    Loading leToolbox.cxt
    Loading lce.cxt
    Loading hsm.cxt
    The QRC UI context file was successfully loaded
    Loading sna.cxt
    INFO: Adding Quantus QRC SND Analysis into Assura Menu
    Thanks for the extra info. That was helpful.
    From this I've figured out what is wrong (hopefully it's what I think it is). I think you have $QRC_HOME set, but do not have "qrc" in the UNIX path before you start virtuoso. If I do that, then I see exactly the same symptoms as you (no Assura->Run Quantus QRC menu, and the QRC->Run Assura - Quantus QRC is greyed out). In the terminal, check if:
    echo $PATH
    contains the path to $QRC_HOME/bin. Also see what "which qrc"  returns, and what "qrc -v" returns in the terminal window.
    Finally, check what _vuiGetQRCVersion() returns in the CIW.
  • manudupouy
    Unfortunately, I think the problem is other. It all seems to be normal.
    [bit@cds ~]$echo $PATH
    /usr/lib64/qt-3.3/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/sbin:/usr/sbin:/sbin:/opt/cadence/IC617/bin:/opt/cadence/IC617/tools/bin:/opt/cadence/IC617/tools/dfII/bin:/opt/cadence/SPECTRE171/bin:/opt/cadence/SPECTRE171/tools/bin:/opt/cadence/SPECTRE171/tools/dfII/bin:/opt/cadence/EXT181/bin:/opt/cadence/EXT181/tools/bin:/opt/cadence/EXT181/tools/dfII/bin:/opt/cadence/ASSURA41/bin:/opt/cadence/ASSURA41/tools/bin:/opt/cadence/ASSURA41/tools/dfII/bin:/opt/cadence/INCISIV141/bin:/opt/cadence/INCISIV141/tools/bin:/opt/cadence/INCISIV141/tools/dfII/bin:/opt/cadence/RC141/bin:/opt/cadence/RC141/tools/bin:/opt/cadence/RC141/tools/dfII/bin:/opt/cadence/EDI141/bin:/opt/cadence/EDI141/tools/bin:/opt/cadence/EDI141/tools/dfII/bin:/home/bit/bin
    [bit@cds ~]$ which qrc
    /opt/cadence/EXT181/bin/qrc
    [bit@cds ~]$ qrc -v
    WARNING: HOST <cds> DOES NOT APPEAR TO BE A CADENCE SUPPORTED LINUX CONFIGURATION.
             For More Info,  Please Run '<cdsroot>/tools.lnx86/bin/checkSysConf' <productId>.
    Name           : qrc - Quantus QRC - (64-bit)
    Description    : Quantus QRC Extraction program
    Version        : 18.1.1-s116
    Build Ref. No. : 116
    IR Build No.   : 116
    Build Date     : Mon Mar 12 21:28:58 PDT 2018
    Copyright 2018 Cadence Design Systems, Inc.
    All rights reserved.
    THIS PROGRAM IS CONFIDENTIAL AND PROPRIETARY
    TO CADENCE DESIGN SYSTEMS, INC. AND CONSTITUTES
    A VALUABLE TRADE SECRET.
    This work may not be copied, modified, re-published,
    uploaded, executed, or distributed in any way, in any
    medium, whether in whole or in part, without prior
    written permission from Cadence Design Systems, Inc.
    Thanks. You didn't say what _vuiGetQRCVersion() returns - can you show that (you'll have had to have opened a layout window first)?
    Also, can you provide what these output (both in the CIW)?
    _vuiGetQRCContext()
    system.??
    In the terminal window, can  you  run "cds_plat" and post what is returned?
  • manudupouy
    Sorry Andrew, I forgot. Here are the results:
    _vuiGetQRCVersion()
    *Error* eval: undefined function - _vuiGetQRCVersion
    system.??
    (name "Linux" plat "lnx86" dirBrkChrs
        "/" dirSepChr "/" pathSep ":"
        shLibExt ".so" LP64 t P64
        t
    [bit@cds TSMC-CR018]$ cds_plat
    lnx86
