  3. Greyed menu: "Run Assura Quantus QRC..." and "Run Assura...
  • Replies 35
  • Views 30380
Greyed menu: "Run Assura Quantus QRC..." and "Run Assura Quantus QRC..."
manudupouy
manudupouy over 8 years ago
All is in the title. I can not run Quantus QRC because it greyed in QRC menu and don't know why.
Someone can help?
Best regards,
wighou
    Andrew Beckett over 8 years ago in reply to manudupouy
    You need to do it after opening a layout window (so that Assura has initialised - I said that before). So I need that and both the _vui function output including _vuiGetQRCContext()
  • manudupouy
    manudupouy over 8 years ago in reply to Andrew Beckett
    OK, sorry again. I have to pay more attention.
    _vuiGetQRCVersion()
    0
    _vuiGetQRCContext()
    "/opt/cadence/EXT181/tools.lnx86/extraction/bin/64bit/etc/context/6.1.0/64bit/qrc.cxt"
    OK, we’re getting close. The first returning 0 is why the menus get messed up. Now just need to figure out why it returns 0.
    I’m on a plane now so this will need to wait until a bit later to debug further.
    To be honest, doing this via the forums is not the most efficient way of solving this - thanks for your patience.
  • manudupouy
    OK Andrew. It's I who thank you.
    I know it is a bit frustrating to have to wait for the return of a simple command.
    Thanks again,
    wighou
    wighou,
    I thought I'd found a possible explanation, but I'm not convinced this can be it because if I mess with this the QRC menu doesn't appear at all and I get some different warnings in the CIW. Anyway, just in case, can you open the layout window as before and then do:
    rexMagic()
    I'm interested if this returns nil. If it does, try:
    rexMagic(t)
    _vuiGetQRCVersion()
    and see if that returns something other than zero. Otherwise, try doing this:
    trace(_vuiGetQRCVersion _vuiEvalQRCVersion)
    tracev(qrcVer version qrcOk)
    _vuiGetQRCVersion()
    and paste here what you get.
  • manudupouy
    I had a problem of moderation I think. I will begin with this first part:
    rexMagic()
    t
    _vuiEvalQRCVersion(_vuiGetQRCVersion)
    |[1]qrcVer set to unbound, was unbound
    |[1]version set to unbound, was unbound
    |[1]qrcOk set to unbound, was unbound
    (qrcOk version qrcVer)
  • manudupouy
    manudupouy over 8 years ago in reply to manudupouy
    and the second part (_vuiGetQRCVersion() response), you can find here: https://file.io/NGbhKi
    I just get a "file.io 404 Page not found" error if I try to follow that link. Can you not attach it as a text file here if it won't let you paste it? If it goes into moderation, I can approve it - although I've not seen anything that needs approval. Use the Insert->Image/video/file below...
  • manudupouy
    Fullscreen _vuiGetQRCVersion.txt Download
    _vuiGetQRCVersion()
    |[1]_vuiGetQRCVersion()
    |[2]version set to nil, was unbound
    |[2]qrcVer set to 0, was unbound
    |[2]qrcOk set to nil, was unbound
    |[2]version set to "WARNING: HOST <cdsbox> DOES NOT APPEAR TO BE A CADENCE SUPPORTED LINUX CONFIGURATION.\n", was nil
    |[2]_vuiEvalQRCVersion(...)
    |[2]version set to "WARNING: HOST <cdsbox> DOES NOT APPEAR TO BE A CADENCE SUPPORTED LINUX CONFIGURATION.\n", was "WARNING: HOST <cdsbox> DOES NOT APPEAR TO BE A CADENCE SUPPORTED LINUX CONFIGURATION.\n"
    |[3]qrcVer set to nil, was 0
    |[3]qrcVer set to 0, was nil
    |[2]qrcVer set to 0, was 0
    |[2]_vuiEvalQRCVersion --> ...
    |[2]qrcOk set to nil, was nil
    |[2]version set to "         For More Info,  Please Run '<cdsroot>/tools.lnx86/bin/checkSysConf' <productId>.\n", was "WARNING: HOST <cdsbox> DOES NOT APPEAR TO BE A CADENCE SUPPORTED LINUX CONFIGURATION.\n"
    |[2]version set to "         For More Info,  Please Run '<cdsroot>/tools.lnx86/bin/checkSysConf' <productId>.\n", was "         For More Info,  Please Run '<cdsroot>/tools.lnx86/bin/checkSysConf' <productId>.\n"
    |[2]version set to "WARNING: HOST <cdsbox> DOES NOT APPEAR TO BE A CADENCE SUPPORTED LINUX CONFIGURATION.\n", was "         For More Info,  Please Run '<cdsroot>/tools.lnx86/bin/checkSysConf' <productId>.\n"
    |[1]qrcOk set to unbound, was nil
    |[1]qrcVer set to unbound, was 0
    |[1]version set to unbound, was "         For More Info,  Please Run '<cdsroot>/tools.lnx86/bin/checkSysConf' <productId>.\n"
    |[1]_vuiGetQRCVersion --> 0
    0
    Thanks for the additional data.
    OK, it is in fact because you're running on an unsupported OS.
    What's happening is that the message about this being an unsupported machine is being output before the qrc -v output, and because of this the version checking code doesn't ever see the qrc version number. When I first looked at this I thought that it was reading the entire output from the "qrc -v" command, but because the wrapper first outputs the unsupported platform before the main qrc executable prints the version, the problem occurs.
    I managed to try it on a CentOS machine, and see exactly the same problem.
