  3. Check Mosfet operation region with Checks/Asserts
  • Replies 9
  • Views 6741
LukiLeu
LukiLeu over 8 years ago
In ADE L I could check the mosfet operation region with the "Device Checking" Tool. I recently switched to ADE Explorer and wanted to do there the same. However I cannot get to set up the wanted check in the "Checks/Assert" Form. I added ther the following data:
- Subs: My devices (eg. nmos4 pmos4)
- Param: region
- Values: tried 3, sat
- Analyses: dcOP
However it keeps saying that there are no violations but with the Device Checking Tool there are violations reported. How do I need to set up the Checks/Assert Form to achieve the same?
Kind regards
Lukas
  • Saloni Chhabra
    Saloni Chhabra over 8 years ago +1
    Hi Lukas, I think that the document below should help you setup your device checks. Please refer to chapter 3 in particular which explains the different ways of setting up and running operating region…
  • Saloni Chhabra
    Hi Lukas,
    I think that the document below should help you setup your device checks. Please refer to chapter 3 in particular which explains the different ways of setting up and running operating region checks on devices in Explorer.
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O0V0000090teVUAQ&pageName=ArticleContent&sq=005d0000001T4VEAA0_201852911117885
    Hope this helps.
    Saloni
  • LukiLeu
    LukiLeu over 8 years ago in reply to Saloni Chhabra
    Hi Saloni,
    The section  "Operating Points Output – OP Region Spec" in your document described exactly what I was searching for! Thanks.
    Lukas
  • LukiLeu
    However, now I got a strange behaviour. It worked fine first, but then I changed something in the schematic. Now the checks always fail with the message:
    *Error* ("eval" 0 t nil ("*Error* eval: unbound variable" region))
    I tried also to delete all checks and add them again, but the same error keeps appearing. Do you have any idea?
  • LukiLeu
    LukiLeu over 8 years ago in reply to LukiLeu
    If I revert the maestro view to where I haven't added the operating point check and then add it again it works again till I change something in the schematic. I then need to revert the view again and add the check again. Any ideas in how to resolve this without the need to revert the view to the point before I added the check?
    Andrew Beckett over 8 years ago in reply to LukiLeu
    Which IC subversion are you using? What does getVersion(t) return in the CIW (also shown in Help->About).
    There was a bug in IC615 where this was broken (fixed in 6.1.5.500.10, I think) - sounds a bit like that, although this is quite an old version...
  • LukiLeu
    LukiLeu over 8 years ago in reply to Andrew Beckett
    I am using IC6.1.7.500.4.
    I also found out, that if I delete the check before I change the schematic and add the check again after the change of the schematic, it will run.
    OK, we'll need to do some checking to see if it was broken more recently (or if it's still broken). Thanks for the version info - that helps enormously.
  • LukiLeu
    It seems to work correctly, when I don't add to much devices with too much conditions.
    Eg. When it didn't worked I had about 20'000 checks active. Now I have only 2400 checks active and I can change something in the schematic and it keeps working, without that I need to remove the check first, change something in the schematic and add the checks again.
    This seems unlikely that it's based on on the number of checks - but maybe there's a bug with your particular set of data.
    Please contact customer support so that we can look at it.
