  3. VerilogA code error:signal exceeds blowup limit
  • Views 11080
Sandeep4386
Sandeep4386 over 8 years ago
I want to write a VerilogA model which monitors input current and prints a message if it is above certain level. I also want output to be same as input current.
I wrote a model and it works but throws out below error when I add a line for output current to be equal to input. Any suggestions what I'm doing wrong here?
[code]`include "constants.vams"
`include "disciplines.vams"
module CurrentMonitor_VlogA(Iin,Iout);
input Iin;
output Iout;
electrical Iin,Iout;
real Ivalue;
parameter real IT2Limit=1m;
analog begin
Ivalue=I(Iin);
I(Iout)<+I(Iin);
if (Ivalue>=IT2Limit)
$strobe("WARNING:Value of current at node Iin has exceeded %g at %m, Iin=%g at simulation time t=%e",IT2Limit,Ivalue,$abstime);
else
$strobe("Current at node Iin=%g, simulation time=%e",Ivalue,$abstime);
end
endmodule[/code]
Here is the error message:
   ERROR (SPECTRE-16384): Signal V(Iout) = -732.434 GV exceeds the blowup limit for the quantity `V' which is (1 GV). It is likely that the circuit is unstable. If you really want signals this large, set the `blowup' parameter of this quantity to a larger value.
  • Saloni Chhabra
    Saloni Chhabra over 8 years ago
    You might want to modify the current contribution statement to (note the '-' sign):
    I(Iout) <+ -I(Iin);
    If the current flowing into the model/block is assumed positive, then the current flowing out should be negative i.e.have inverse polarity. So, this could be one of the reasons why your circuit is struggling to converge.
    Saloni
  • Sandeep4386
    Sandeep4386 over 8 years ago in reply to Saloni Chhabra
    Thanks Saloni for your suggestion.
    I tried that but now I have the same error with opposite polarity on output voltage blow up limit as shown below:
        ERROR (SPECTRE-16384): Signal V(Iout) = 732.434 GV exceeds the blowup limit for the quantity `V' which is (1 GV). It is likely that the circuit is unstable. If you really want signals this large, set the `blowup' parameter of this quantity to a larger value.
    I tried to model output voltage but it won't let me. Any further suggestions?
  • Saloni Chhabra
    Saloni Chhabra over 8 years ago in reply to Sandeep4386
    What have you connected to the output of this current mirror? And what is the value of the current on Iin? As the convergence error is due to the voltage being generated at the output of your model, can you share your complete input.scs for further analysis.
  • Sandeep4386
    Hi Saloni,
    Good catch, output node was left open, once I connected it to a load, I could run the sim with no issues. Thank you very much for your help.
    Andrew Beckett over 8 years ago in reply to Sandeep4386
    I wondered whether you really wanted to have a current controlled source as part of your monitor - this seems unnecessary. Perhaps you wanted just a probe - the code below creates a zero-volt source between the input and output and measures the current flowing through that source.
    Note I changed the text of the output messages because there's no such thing as the current at a node (the current at a node should be 0, because of Kirchoff's current law):
    inout Iin;
    inout Iout;
    real Ivalue;
    analog begin
      Ivalue=I(Iin,Iout);
      V(Iin,Iout)<+0;
        $strobe("WARNING:Value of current through %M has exceeded %g at %m, value=%g at simulation time t=%e",IT2Limit,Ivalue,$abstime);
      else
        $strobe("Current through %M=%g, simulation time=%e",Ivalue,$abstime);
    end
    endmodule
  • Sandeep4386
    Sandeep4386 over 8 years ago in reply to Andrew Beckett
    This is much better approach and exactly what I needed. Thank you!
