  3. Missing Instances - inductor (lsps_otc)
  • Views 4251
Min Zee
Min Zee over 8 years ago
I am using lsps_otc in my design. I had added guard ring (pring) and connected it to ground.
But when I run LVS it complains "missing instances" to all the lsps_otc.
May I know how to connect lsps_otc to ground?
    What's "lsps_otc"? Presumably it's the name of an inductor in your design (not sure how anyone could know that without you explaining more).
    My guess is that there's no recognition layer for the LVS tool (which I'm guessing is Calibre - which by the way is a Mentor Siemens tool, not a Cadence tool, so not a great question for these forums) and so it's extracting the inductor just as a connection between the two inductor ports.
    You'd need to look at the documentation for your technology setup and the LVS rules to find out if there is a way to identify coils of metal as an inductor rather than just a track.
