  3. Cadence Liberate Characterization Help
  • Replies 48
  • Views 42880
anurans
anurans over 8 years ago
Hi All,
For the characterization of a standard cell library, I am using LIBERATE_15.14.070 version. The cell spice model was generated using IC6.1.5, and I am using Spectre as the external simulator for the characterization. I have a question specifically on the leakage_power nodes of the .lib file generated by Liberate. For an example, for a simple inverter, I ended up having leakage_power values as follows (in the link):
https://pastebin.com/grfasa1s
However the resulting leakage values do not follow the circuit simulation values in IC6-Spectre.
> Can anybody explain why the leakage value related to VSS pin is always 0 ?
> How does the Liberate calculate these values ? Is there a way to evaluate the accuracy of Liberate-Spectre simulation ?
Thanks in advance
Anuradha
  • Guangjun Cao
    Guangjun Cao over 8 years ago +1
    Hi Anuradha, First of all, please move to the latest Liberate release, 17.1.3. When characterising leakage power, by default, the measured dc current will be multiplied by the supply voltage. This…
  • sazjad
    sazjad over 7 years ago in reply to Guangjun Cao
    Hi Cao,
    I am not getting any error and characterization was finished successfully. None of the cells are listed in 'List of failing cells'.
    I have made the changes as you suggested but I am still seeing the "cell_leakage_power: 0" and "function: 0".
    Can you please suggest anything else that might solve this issue?
    By the way, there are couple of folders generated in the spice deck. What is the proper way of debugging if there is any error?
    Thank you for your time and help.
    Best regards,
    Hossain.
  • anurans
    anurans over 7 years ago in reply to sazjad
    Seems like define_leakage is missing in your template file.
    set cells { \
        INVX1 \
    define_leakage -when "(in * !(out))" INVX1
    define_leakage -when "(!(in) * out)" INVX1
    define_template -type delay \
    Anuradha
  • Guangjun Cao
    Guangjun Cao over 7 years ago in reply to sazjad
    under the directory you specified with extsim_deck_dir, there are compressed files for each cell. unpack the corresponding tarball. you will see a map.lst file, which describes the mapping of arcs and directories. in each leaf directory, there is a sim.sp. open the file and remove save/nosave option. save a file and run spectre on this file. after the run, using Viva to view the waveform. For leakage, you need to refer to Liberate documentation on how leakage is calculated.
    With the char_library command option, you do not need any define_leakage or define_arc commands.
    there is also an example directory in liberate installation directory, which can be used as reference.
    Good luck.
    Guangjun
  • anurans
    Hi, Cao is right ! char_library automatically calculates leakage if not specifically written.
    Anuradha
  • sazjad
    Hi Cao and Anuradha,
    Thank you for your suggestions. It seems like I can generate the .lib file successfully using the fictitious model file provided with the tool. However, whenever I am using NCSU 45nm model file, it's failing to show leakage power and function. I am assuming there are some compatibility issues between model files and netlist. Please correct me if I am wrong.
    I have attached the inverter netlist here ( http://ge.tt/888n5zr2 ) that was extracted using NCSU 45nm PDK and also attached a copy of NCSU model file for NMOS here
    ( http://ge.tt/3J3w5zr2 )
    I have also attached the fictitious model file here ( http://ge.tt/6Wrt5zr2 ) that was provided with the tool.
    I have looked into the spice deck for both cases and I don't see any transistor or model file definition in the sim.sp (see http://ge.tt/6uw46zr2 ) for NCSU 45nm PDK as I have seen with fictitious model (see http://ge.tt/8gFz5zr2 ).
    Thank you so much for your time and help. Any suggestion would be very helpful.
    Hossain
  • Guangjun Cao
    I can not find out the reason with what you have provided. It could be some problems with your input data or the settings. Also, please try -extsim spectre option in your char_library command.
    If you need further help, please submit a Case, and provide a test case with the run results as they are.
    Guangjun
  • sazjad
    Hi Cao,
    I have used -extsim spectre option, but still having the same issue; its not generating the leakage power.
    Unfortunately I don't have the access to submit a case. I think as an academic user I only have access to online support database. I will keep trying to see if I can fix this issue.
    Thank you for your help and time.
    Best regards,
    Hossain
  • Guangjun Cao
    can you show me the full logfile?
  • sazjad
    Hi Cao,
    Sure. The log file is included in this (http://ge.tt/9DDpc4s2) link.
    Thank you.
    Best regards,
    Hossain
  • Guangjun Cao
    You are using a very old Liberate release. Please download the latest release first.
    There are many warnings in your logfile. The most critical one might be during netlist parsing, "Warning from parser during circuit read-in...". These warnings could mean no devices are recognized correctly.
    After "generating vectors...", you should see timing related information, in addition to power/leakage. But they do not exist.
    So, the most possible issue is in your netlist and/or model files.
    regards,
    Guangjun
