  3. any specific env var to control "Only check views with explicit...
  • Views 1538
any specific env var to control "Only check views with explicit pin order" in VSE Cross-View Checker?
zssfred
zssfred over 8 years ago
In GUI, there is a trigger like below:
And how do I trigger it via env var? There is "vicCheckPinOrder", but it looks like the superset -- "Check Pin Order".
I am using IC6.1.7.is12.
Fred
  • Marc Heise
    Marc Heise over 8 years ago
    Hi Fred,
    schematic  vicIgnoreViewsWithNoSetPinOrder    t/nil  boolean
    There is an easy way to find a variable (if it exist) for a gui setting.  Save all variables to a file  ( CIW Options Save Defaults ),  make a  change to the gui setting, save to different file, diff the files.
    I personally prefer the search assistant, since it is searching and displaying the envVars as well  (set a filter to only search the envVars to avoid long search times or too many hits), and most envVars
    can be kind of guessed, at least parts of the envVar name.  Like I searched for "pinorder" in this case.
    Marc
  • zssfred
    zssfred over 8 years ago in reply to Marc Heise
    Marc,
    Cool!
    Thank you so much!
    Fred
