  3. Cadence Calculator functions
  • Views 23394
mhkvy4
mhkvy4 over 8 years ago
I am seeking help to know if there is a built-in function in the Cadence calculator which accomplishes what I need. I have to signals 1 and 2. The first signal is a square pulse and the second signal is a ramp. I need to know the x value when signal 1 crosses a certain threshold. I know I can do this using the cross function. At the same x value I need to know the corresponding y value on signal 2. Is there a way to do this using calculator functions or building your own expression incorporating the "cross" function?
  • Saloni Chhabra
    Saloni Chhabra over 8 years ago
    I assume you are looking for 'value' function in the calculator. It returns the y value of a signal at a user-defined time value (you will get this value using cross on signal 1).
    Saloni
  • mhkvy4
    mhkvy4 over 8 years ago in reply to Saloni Chhabra
    Thanks Ms. Chhabra, that  was it.
