  3. deepprobe with analog extract
  • Views 25437
jazzmatazz
jazzmatazz over 8 years ago
I'm using deepprobe in my simulation, but when replace the schematic view with analog extract it's stops working.
For sim with schematic I use such syntax for access some net
top_level.level1.level0.net_name
In analog extract no hierarchy, and the same net is renamed to
level1|level0|net_name
 I've put in the deeprobe properties
top_level.level1|level0|net_name
But simulation can't start because of the error " Unexpected operator "|"
What syntax should I use in this case?
Nikolay
    Hi Nikolay,
    Without doing any experimentation to check, I expect you will need to escape the pipe characters with a backslash:
    top_level.level1\|level0\|net_name
  • Frank Wiedmann
    Frank Wiedmann over 8 years ago in reply to Andrew Beckett
    The italics might make this a little confusing for some people: the backslash looks like a pipe character and the pipe character looks like a slash. So, as a public service, here is the same name without italics:
  • jazzmatazz
    jazzmatazz over 8 years ago in reply to Andrew Beckett
    Thanks Andrew it's working.
    Nikolay
