  3. ADEXL SDB XML syntax question
  • Views 15941
JosephS
JosephS over 8 years ago
I am trying to find any documentation on the expected xml syntax for an sdb file to be loaded for corner setup.   Maybe a list of the expected keywords and/or values.  Examples might be good but I have a few already that do not help as they are very simple ones.
Regards
Joe
    Hi Joe,
    The format itself is not documented (I've never entirely understood our reluctance to document this, given that it's an export and import format from the corners tool). That said, it's straightforward enough to use the UI to export a sample of data, and then adapt it to your needs - the format itself is quite straightforward.
  • karthikeyan123
    karthikeyan123 over 7 years ago in reply to Andrew Beckett
    Iam new to skill can you help me how to import an xml document.
  • karthikeyan123
    Then text document data has to be converted into xml document that data need to be print in another xml outfile.
    Andrew Beckett over 7 years ago in reply to karthikeyan123
    What are you actually asking? This thread is specifically about the XML syntax for corner simulation setup in ADE XL/Explorer/Assembler. Is your question related to that somehow? If so, what is the issue you're facing?
