  3. Consistent Pcell naming scheme for strmout
  • Views 15632
rotanudad
rotanudad over 8 years ago
I'm currently on ICADV12.3-64b and I'm looking for a way to generate a gds file such that the instance names for Pcells(or any other cells that do not have unique names) are the same(e.g suffix is a counter which counts up for every instance encountered) each time I strmout  a gds.
So far, I've tried options such as "flatten PCells" and  "flatten Vias" when exporting the gds, but the results of the fastxor run do not seem to match the fastxor run where I select "create gdsii"(let fastxor create the two gds's).
I need this so that I can run fastxor on a list of cells that exist in multiple libraries through the command line.
Thanks.
    Not sure you really mean instance names since stream format doesn't normally store instance names. Perhaps you mean the structure (cell) names used for each variant of the pcell that's used?
    You can turn off the timestamp part of the mapped cell name by going to More Options->General and then turning on "Ignore current timestamp". Perhaps that's what you want?
  • rotanudad
    rotanudad over 8 years ago in reply to Andrew Beckett
    Yes that is what I mean, and thank you for the feedback.
    I've tried your suggestion to disable the timestamp, and the results appear to be more similar, but not the same as the gds's generate from the fastxor gui.
    When I stream back the generated gds from both the streamout and the fastxor gui, I see that the counter for the pcell variants are different.
    So I guess a better question is how do I have a streamout(strmout) that looks exactly like the gds that the fastxor gui is generating?
