  3. Check if a library exists in cds.lib or included cds.lib...
  • Views 17436
Check if a library exists in cds.lib or included cds.lib files from terminal
bala000
bala000 over 8 years ago
Is there any cadence utility to check if a library is defined in cds.lib or any included files? I wish to use the utility from terminal.
Bala
    Andrew Beckett over 8 years ago +1
    Bala, You could use the output of the "cdsLibDebug" UNIX command, perhaps? Regards, Andrew.
    Bala,
