  3. Assura Default License
  • Views 16350
0nTheG0
0nTheG0 over 8 years ago
Hello:
I run Assura LVS and it returns a license error:
Run 'lic_error LMF-02012' for more information.
Failed to obtain license for "Assura_LVS".
Checking out license for Phys_Ver_Sys_LVS_XL
LVS ultimately does run after several minutes with trying a different license: "Phys_Ver_Sys_LVS_XL".  Is there a way to tell Assura to use this license first by default?
Assura (R) Physical Verification Version av4.1:Production:dfII6.1.6-64b:IC6.1.6-64b.500.14
Release 4.1_USR5_HF14
  • Saloni Chhabra
    Saloni Chhabra over 8 years ago
    Hi Eric,
    Can you check if you have access to the article below:
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O0V000006AkMZUA0&pageName=ArticleContent&sq=005d0000001T4VEAA0_20187310043945
    To summarize, the default behaviour of Assura is to first checkout Assura licenses, but by setting an environment variable, you can tell it to use PVS licenses instead. So, run this before launching Virtuoso or Assura:
    setenv ASSURA_USE_PVS_LICENSE
    Saloni
  • 0nTheG0
    0nTheG0 over 8 years ago in reply to Saloni Chhabra
    Thanks Saloni, that did it!
