  3. Plot transient OP vs. Time
  • Views 20386
HoWei
HoWei over 8 years ago
I want to plot the transient operating point of a device versus time (e.g device Msrowin, operating point for ids).
One way to achieve this is to create a file "tran_op.scs" and include it with the model files. The file content will be:
             save Mswroin:ids
In the output definitions I would add:  getData("Mswroin:ids" ?result 'tran), then I can plot the "ids" versus time.
Questions:
1) How should the file syntax look like, when the device is in a subcircuit (e.g "/DUT/Mswroin" does not work) ?
2) Is there another (easier) way to evaluate the transient operating point vs. time ?
    1. save DUT.Mswroin:ids    (you need to use spectre's hierarchy separator, and use the names that appear in the netlist)
    2. In ADE (for some time now), use Outputs->To be saved->Select OP Parameters and then you can click on the device(s) in the schematic and say which parameters you wish to save, and whether you want them auto-plotted or not. This adds a new tab in the ADE outputs. The calculator also adds OPT (for transient) and OS (for DC sweep) buttons to allow you to retrieve the results back into the calculator.
  • HoWei
    HoWei over 8 years ago in reply to Andrew Beckett
    The output equation OT("/DUT/Mswroin" "vsat_marg") does evaluate the transient operating point versus time. No need for model file inclusion any more.
    Thanks, your answer pointed me into the right direction !
