  3. ADE Assembler sweep config views problem
  • Views 15164
michael10
michael10 over 8 years ago
I have a simulation setup in ADE Assembler including a sweep of configs of a sub-module (like expained here: community.cadence.com/.../sweeping-multiple-config-views).
Let's say I have a config_a and a config_b for two different versions of a sub-module.
The config of my tests includes config_a as default.
In one test, I save the DC Operating Point together with some other outputs.
After the simulation, I can right-click on any output of this test, and then select Annotate -> DC Node Voltage.
The problem is, that the annotation only works for the default config (config_a), but not for the sweeped config (config_b).
If I try to annotate the DC Node Voltage for the sweep of config_b, the schematic of config_a is opened instead of the schematic of config_b.
Same for right-click-Direct Plot>-..., Print->...
Question:
Is it possible to use Annotate / Direct Plot / ... for sweeped config views in ADE Assembler after simulation?
Info:
Cadence IC6.1.7-500.15
