  3. Gravity Snapping in IC 6.1.7
  • Views 18369
stefan6
stefan6 over 8 years ago
How can I enable gravity snapping to center of objects/layers in Cadence Virtuoso Layout? This was previously available as a check box in the Layout Editor Options.
Thanks.
    Andrew Beckett over 8 years ago +1
    The gravity capability was changed to make it simpler in IC617, but there's still been quite a lot of demand to provide the flexibility there was before. The good news is that it's still there, just not…
    The gravity capability was changed to make it simpler in IC617, but there's still been quite a lot of demand to provide the flexibility there was before. The good news is that it's still there, just not on the form.
    See Gravity controls missing from IC6.1.7 Virtuoso Layout Editor Options form (there's also a CCR to request that the detailed gravity controls are restored to the options form).
    A colleague in my team (thanks Norman!) wrote this code a while back which you can use in the meantime:
    procedure( CCScreateMyGravityForm()
            let( (label all none centerline edge midpoint vertex end nexus pin
                                    origin distance depth)
                    label=hiCreateLabel(
                            ?name 'type
                            ?labelText "Types")
                    all=hiCreateBooleanButton(
                            ?name 'all
                            ?defValue t
                            ?buttonText "all"
                            ?buttonLocation 'left
                            ?callback "CCSsetAllTypesOn(hiGetCurrentForm())" )
                    none=hiCreateBooleanButton(
                            ?name 'none
                            ?defValue nil
                            ?buttonText "none"
                            ?callback "CCSsetAllTypesOff(hiGetCurrentForm())" )
                    centerline=hiCreateBooleanButton(
                            ?name 'centerline
                            ?defValue t
                            ?buttonText "centerline"
                            ?buttonLocation 'left )
                    edge=hiCreateBooleanButton(
                            ?name 'edge
                            ?defValue t
                            ?buttonText "edge"
                    midpoint=hiCreateBooleanButton(
                            ?name 'midpoint
                            ?defValue t
                            ?buttonText "midpoint"
                    vertex=hiCreateBooleanButton(
                            ?name 'vertex
                            ?defValue t
                            ?buttonText "vertex"
                    end=hiCreateBooleanButton(
                            ?name 'end
                            ?defValue t
                            ?buttonText "end"
                    nexus=hiCreateBooleanButton(
                            ?name 'nexus
                            ?defValue t
                            ?buttonText "nexus"
                    pin=hiCreateBooleanButton(
                            ?name 'pin
                            ?defValue t
                            ?buttonText "pin"
                    origin=hiCreateBooleanButton(
                            ?name 'origin
                            ?defValue t
                            ?buttonText "origin"
                    distance=hiCreateCyclicField(
                            ?name 'distance
                            ?prompt "Distance"
                            ?choices list("Small" "Medium" "Large" "Very Large")
                            ?defValue "Large")
                    depth=hiCreateIntField(
                            ?name 'depth
                            ?value 3
                            ?prompt "Depth")
                    hiCreateAppForm(
                            ?name 'gravityOptionsForm
                            ?formTitle "Gravity Controls"
                            ?fields list(
                              list(label 0:0 100:10)
                                                            list(all 100:0 100:10)
                                                            list(none 200:0 100:10)
                                                            list(centerline 0:20 100:10)
                                                            list(edge 100:20 100:10)
                                                            list(midpoint 200:20 100:10)
                                                            list(vertex 0:40 100:10)
                                                            list(end 100:40 100:10)
                                                            list(nexus 200:40 100:10)
                                                            list(pin 0:60 100:10)
                                                            list(origin 100:60 100:10)
                                                            list(distance 0:80 100:10 70)
                                                            list(depth 200:80 100:10 70)
                            ?buttonLayout 'OKCancelApply
                            ?callback 'CCSsetGravityOptions
                            ?dontBlock t
    procedure(CCSsetAllTypesOn(theForm)
      theForm->none->value=nil
            theForm->centerline->value=t
            theForm->edge->value=t
            theForm->midpoint->value=t
            theForm->vertex->value=t
            theForm->end->value=t
            theForm->nexus->value=t
            theForm->pin->value=t
            theForm->origin->value=t
    procedure(CCSsetAllTypesOff(theForm)
      theForm->all->value=nil
            theForm->centerline->value=nil
            theForm->edge->value=nil
            theForm->midpoint->value=nil
            theForm->vertex->value=nil
            theForm->end->value=nil
            theForm->nexus->value=nil
            theForm->pin->value=nil
            theForm->origin->value=nil
    procedure(CCSsetGravityOptions(theForm)
            let((value)
      value = " "
      when(theForm->centerline->value value=strcat(value " centerline"))
            when(theForm->edge->value value=strcat(value " edge"))
      when(theForm->midpoint->value value=strcat(value " midpoint"))
      when(theForm->vertex->value value=strcat(value " vertex"))
            when(theForm->end->value value=strcat(value " end"))
      when(theForm->nexus->value value=strcat(value " nexus"))
            when(theForm->pin->value value=strcat(value " pin"))
      when(theForm->origin->value value=strcat(value " origin"))
            envSetVal("layout" "gravityType" 'string value)
            printf("gravity type settings : %L\n" leGetEnv("gravityType"))
            envSetVal("layout" "gravityDistance" 'string theForm->distance->value)
            printf("gravity distance setting : %s\n" leGetEnv("gravityDistance"))
      envSetVal("layout" "gravityDepth" 'int theForm->depth->value)
            printf("gravity depth setting : %d\n" leGetEnv("gravityDepth"))
    procedure(CCSmyGravity()
      unless(boundp('gravityOptionsForm)
            hiDisplayForm('gravityOptionsForm)
    hiSetBindKey("Layout" "<Key>F8" "CCSmyGravity()")
  • stefan6
    stefan6 over 8 years ago in reply to Andrew Beckett
    It works flawlessly! Thanks,
    Stefan
