  3. Accessing ADE XL global variables from within systemverilog...
  • Views 16441
Accessing ADE XL global variables from within systemverilog block
Abel Ace
Abel Ace over 8 years ago
Using ADE XL.  I've got a Spectre DUT and am using systemverilog to generate my testbench stimuli.
I need to access global variables from within the SV testbench so that I can uniquify result filenames.
How can I do this?  Thank you.
    Assuming you're running a simulation with "ams" as the simulator (since spectre doesn't understand SystemVerilog), the ams netlister should create a "cds_globals" module with each of the global variables in, and then you can use an out-of-module reference to access cds_globals.varName from within your SystemVerilog test bench.
    That's also assuming I've understood your question properly.
  • Abel Ace
    Abel Ace over 8 years ago in reply to Andrew Beckett
    Works great, just what I needed.  Thank you Andrew!
