  3. PVS LVS reporting missing pins in Layout
  • Views 24610
Waleed Mansha
Waleed Mansha over 8 years ago
I have done the layout of a cell and included all the pins that were in the schematic by using "generate selected from source" for each one of them and choosing the appropriate pin layer. The "connectivity -> check --> against source"  and "connectivity--> update --> components and nets" validates that the pins have bee placed.
DRC with PVS is clean.
Running LVS with PVS results in mismatch showing all pins are missing in layout.
  • Saloni Chhabra
    Saloni Chhabra over 8 years ago
    Can you try setting 'Convert Pin' option under 'Input' section of PVS LS form as shown below (and then re-run LVS):
  • Waleed Mansha
    Waleed Mansha over 8 years ago in reply to Saloni Chhabra
    I have tried that but LVS still doesn't recognize any pins.
    My pins are on metal layer with purpose"pin". Their labels are on the same metal layer with purpose "label". I have tried placing the labels on the drawing layer as well but still no luck.
  • Quek
    Quek over 8 years ago in reply to Waleed Mansha
    Hi Waleed
    Perhaps you can try this:
    a. Execute the following cmd in a terminal window:
    terminal> egrep "port -text_layer" /your-path/PVS_LVS.rul
    You may get something similar to this:
    port -text_layer m1_pin
    b. Now execute this:
    terminal> egrep "layer_def m1_pin" /your-path/PVS_LVS.rul
    Output may be similar to this:
    layer_def m1_pin 1087
    c. Now execute this:
    terminal> egrep "layer_map.*1087" /your-path/PVS_LVS.rul
    layer_map 7 -texttype 1 1087
    You now need to know the DFII layer name and purpose of gds number 7 type 1. You can check Virtuoso gds mapping file for the info. E.g.
    Metal1 pin 7 1
    Now we know that you need to use "pin" purpose for the label. : )
    Best regards
    Quek
