  3. Plotting generated waveforms in the same subwindow as simulated...
  • Views 17161
Plotting generated waveforms in the same subwindow as simulated waveforms
CADcasualty
CADcasualty over 8 years ago
I have an ocean script that runs a transient simulation and then creates a waveform using artListToWaveform() that I want to overlay onto the waveform of interest. Frustratingly, when I plot the two waveforms they always end up in two different subwindows. I can plot any number of waveforms from the simulation into the same subwindow, but the created artListToWaveform() waveform simply won't plot in the same subwindow as the "real" waveforms. The x-axis limits for the generated waveform are the same as the real waveforms. Any ideas?
  • CADcasualty
    So I've found the cause of the problem - the generated waveform doesn't have any units and therefore viva plots it in a different subwindow. However, if you right click on the x-axis and select Allow Any Units then both waveforms will plot on the same axes :-). You can configure viva ahead of time by putting the following into your .cdsinit:
    envSetVal("viva.indepAxis" "flexible" 'string "true")
    If you enter the above command into the CIW then viva's original behavior persists until you open up a new plot window.
    So now I guess I'm all set, but I can also ask a follow up question - can I set the independent axis units of my generated waveform to be in seconds?
    Andrew Beckett over 8 years ago in reply to CADcasualty
    See abSetUnits and abSetXUnits in this article. Ah, looks like I've posted the code to the forums too - here.
  • CADcasualty
    CADcasualty over 8 years ago in reply to Andrew Beckett
    These solved all of my problems! I don't even need to bother with the solutions I posted earlier in the thread. Thanks so much!!
