  3. finding at what time does 2 waveform cross each other
  • Views 19424
JagdishP
JagdishP over 8 years ago
In calculator we have a function named "cross" which gives the time at which the respective signal crosses a set value(constant).
if one of the waveform was constant, I would have taken the average value of it and compare the 1st waveform with these average value using cross function.
But what if both the waveforms are random ?
How can i know at what time does the 2 random waveform cross each other? is there any direct function which i can use?
Jagdish
    Hi Jagdish,
    Subtract one waveform from the other, and then use cross to see when it crosses 0.
  • Dimitra Papazoglou
    Dimitra Papazoglou over 8 years ago
    Hi Jagdish,
     In the cross function, you could use the difference of the 2 waveforms as signal and then set the threshold value to 0.
    Dimitra
  • JagdishP
    JagdishP over 8 years ago in reply to Andrew Beckett
    Thanks Andrew, I did the same so that my work is not stopped. But I was looking if there is any direct function.
    Andrew Beckett over 8 years ago in reply to JagdishP
    Hi Jagdish,
    I don't understand why you'd need a "direct" function to do this - this is precisely the kind of expression that would be normal. It would seem an over-complication to provide a special function just to handle this specific case. The overall expression wouldn't be any shorter either!
  • JagdishP
    I totally agree with you, but just out of curiosity, I wanted to know if there is any direct function available.
    Thanks & regards,
    Jagdish
