  3. Uncheck update instances in rename cell dialog
  • Views 14860
wcheong
wcheong over 8 years ago
Is there a way to uncheck the Update Instances box in Rename Cell dialog by default (eg. in .cdsinit)?
    You can put the following entry in your ~/.cdsenv file:
    cdsLibManager.rename updateOn boolean nil
    Note that putting an equivalent envSetVal call in your .cdsinit won't help, because the library manager is a separate process that doesn't read the .cdsinit. So this ideally needs to be in a .cdsenv file which by default looks in your home directory (not working dir). However, it's possible by various methods (either the $CDS_LOAD_ENV Unix env var or using the csfLookupConfig file mechanism) to look for it elsewhere. You could also put:
    envSetVal("cdsLibManager.rename" "updateOn" 'boolean nil)
    into a cdsLibMgr.il file which is found via the Cadence Search File (setup.loc) mechanism - so probably in your home or working dir.
  • wcheong
    wcheong over 8 years ago in reply to Andrew Beckett
    I put the entry into cdsLibMgr.il in my working dir. It works. Thank you very much!
