  3. ADE XL new test addition on a running simulation
  • Views 14474
VEVAD
VEVAD over 8 years ago
How can I add a new test to an existing running ADE XL Simulation? Since it takes a couple of days to run the same I don't want to run it again , so if there is any possible ?
    Andrew Beckett over 8 years ago +1
    If you add the new test, and then use the Reference History toolbar to reference the previous history that ran with the other tests, it can avoid repeating simulations for tests/corners that have already…
    If you add the new test, and then use the Reference History toolbar to reference the previous history that ran with the other tests, it can avoid repeating simulations for tests/corners that have already run. I suggest you try it out on something small to ensure you understand how it works.
