  3. how to set a bindkey to display multiple layers ?
  • Replies 8
  • Views 23309
Nhumai
Nhumai over 8 years ago
I am using cadence 6.1. I am trying to set a bindkey to display certain layers at 1 time. For example key '0' will display base layers, key'1' will display metal1 via2 and metal 2 . I have a simple setup like below but it didn't work. I am not sure what is the missing in this code ? I am new skill code
thanks
Nhumai
hiSetBindKeys( "Layout" list(
 list("<key>1" "pteSetNoneVisible() leSetEntryLayer(list(\"M0\" \"drawing\")) leSetEntryLayer(list(\"M0\" \"pin\")) letSetEntryLayer(list(\"VIA0\" \"drawing\")) leSetEntryLayer(list(\"M1\" \"drawing\")) leSetEntryLayer(list(\"M1\" \"pin\")) leSetEntryLayer(list(\"CM1A\" \"drawing\")) leSetEntryLayer(list(\"CM1B\" \"drawing\")) leSetEntryLayer(list(\"prBoundary\" \"boundary\")) hiRedraw()")
 list("<key>2" "pteSetNoneVisible() leSetEntryLayer(list(\"M1\" \"drawing\")) leSetEntryLayer(list(\"M1\" \"pin\")) letSetEntryLayer(list(\"VIA1\" \"drawing\")) leSetEntryLayer(list(\"M2\" \"drawing\")) leSetEntryLayer(list(\"M2\" \"pin\")) leSetEntryLayer(list(\"CM2B\" \"drawing\")) leSetEntryLayer(list(\"prBoundary\" \"boundary\")) hiRedraw()")
  • Nhumai
    The error I got is undefined function pteSetNoneVisible. I used this setup before and it is working fine. How can I define pteSetNoneVisible ?
    thanks
    Andrew Beckett over 8 years ago in reply to Nhumai
    Which version are you using? i.e. what does getVersion(t) in the CIW report?
    I would have probably used leSetLayerVisible(list("M1" "drawing") t) or pteSetVisible("M1 drawing" t "Layers") rather than setting the entry layer repeatedly, but the fact that the function isn't defined suggests you must be using an old version?
  • Marben
    Marben over 8 years ago
    HI Nhumai,
    ;Usage: Bindkey 0 makes all layer invisible except layer "ref" "drawing" in layout.
     hiSetBindKey("Layout" "<Key>0" "visibility_0()")
     procedure(visibility_0()
      leSetEntryLayer(list("ref" "drawing"))
      leSetAllLayerVisible( nil );
      leSetLayerVisible( list("ref" "drawing") t )
      hiRedraw( )
      printf("\n All layers is set to invisible except ref layer. \n ")
     ;Usage: Bindkey 1 makes layer METAL1, METAL2 and VIA2 drawing visible in layout.
     hiSetBindKey("Layout" "<Key>1" "visibility_1()")
     procedure(visibility_1()
         leSetEntryLayer(list("METAL1" "drawing"))
         leSetLayerVisible( list("METAL1") t )
            leSetLayerVisible( list("METAL1" "drawing") t )
            leSetLayerVisible( list("METAL2" "drawing") t )
            leSetLayerVisible( list("VIA2" "drawing") t )
         hiRedraw( )
         printf("\n METAL1, METAL2 VIA2 dawing is set to visible. \n ")
    I hope this help.
    Best regards,
    Marben
  • Nhumai
    Nhumai over 8 years ago in reply to Andrew Beckett
    when I type getVersion(t) in CIW it show "sub-version Ic6.1.5.500.10" . Let me try leSetLayerVisible(list(Mm1" "drawing") t) first and see if it is working
    thanks
    Nhumai
    • Vote Up -1 Vote Down
  • Nhumai
    Nhumai over 8 years ago in reply to Nhumai
    Hi Andrew
    I have
            list( "<key>4"  leSetLayerVisible(list("nwell" "drawing") t) hiRedraw())
    )) ;; hiSetBindKeys
    it is still doesn't work . It didn't give me any syntax error. It give me the warning  like
    *WARNING* key <key>4 non-EF argument must be type string, not symbol
    *WARNING* key <key>4 EF argument must be type string, not symbol
    Please let me know what happen
    thanks
    Nhumai
    PS. when I type getVersion(t) in CIW it show "sub-version Ic6.1.5.500.10"
  • Nhumai
    Nhumai over 8 years ago in reply to Marben
    Hi Marben,
    It is working fine for me. Thanks a lot
    Nhumai
  • Nhumai
    Hi Marben,
    I expand the script to this kind of set and still it is working fine.
    thanks
      hiRedraw( )
         leSetEntryLayer(list("nwell" "drawing"))
         leSetLayerVisible( list("nwell") t )
            leSetLayerVisible( list("diff" "drawing") t )
            leSetLayerVisible( list("nsdm" "drawing") t )
            leSetLayerVisible( list("psdm" "drawing") t )
            leSetLayerVisible( list("poly" "drawing") t )
            leSetLayerVisible( list("pcon" "drawing") t )
            leSetLayerVisible( list("tap" "drawing") t )
            leSetLayerVisible( list("hvi" "drawing") t )
            leSetLayerVisible( list("litr" "drawing") t )
         hiRedraw( )
         printf("\n base layer is set to visible. \n ")
     procedure(visibility_2()
         leSetEntryLayer(list("met1" "drawing"))
         leSetLayerVisible( list("met1") t )
            leSetLayerVisible( list("met1" "drawing") t )
            leSetLayerVisible( list("met2" "drawing") t )
            leSetLayerVisible( list("via" "drawing") t )
         hiRedraw( )
    hiSetBindKey("Layout" "<Key>2" "visibility_2()")
    Hi Nhumai,
    The function pteSetVisible was added in IC616, so that's why that didn't work - you're using too old a version - even IC616 came out 5½ years ago, and the subversion you're using is even older.
    The reason why the code above failed is because  you didn't put quotes around the command (should have been "leSetLayerVisible(list(\"nwell\" \"drawing\") t) hiRedraw()" )
