  3. Monte Carlo for Verilog A based model file
  • Views 16457
Shobhitkareer
Shobhitkareer over 8 years ago
I created a symbol using verilogA from 3 file which contains the defination for the other module, I created the following modification in the top level file
module FET(Drain,Gate,Source,Sub);
parameter real n1= 2;
parameter real n2=1;
(*cds_inherited_parameter*) parameter real monten1=0;
(*cds_inherited_parameter*) parameter real monten2=0;
localparam real n1_eff = n1 + monten1;
localparam real n2_eff = n2 + monten2;
FET_L2 #(.Lch(Lch),.Lgeff(Lgeff),.Lss(Lss),.Ldd(Ldd),.Efi(Efi),.Kgate(Kgate),.Tox(Tox),.Csub(Csub),.Ccsd(Ccsd),.CoupleRatio(CoupleRatio),.Vfbn(Vfbn),.Dout(Dout),.Sout(Sout),.GF(min(Wgate/1.0e-12,1.0)),.Pitch(Pitch),.CNTPos(1),.n1(n1_eff),.n2(n2_eff)) XNCNFET_L2_edge (int_Drain1, int_Gate1, int_Source1, Sub, int_Drain1);
and then i created a spectreText of the model and included it in the model library
simulator lang=spectre
subckt NCNFET_L3_MC1 Drain Gate Source Sub
parameters monten1 = 10 monten2 = 10
statistics {
mismatch {
vary monten1 dist=gauss std=5
vary monten2 dist=gauss std=5
ends NCNFET_L3_MC
but Im getting the following error:-
The HDL cell-view "shobhit" "NCNFET_L3_MC1" "veriloga" does not have view-specific
simulation data. To create the data please open and save the view.
You may also update the view by executing the following SKILL command:
ahdlUpdateViewInfo("shobhit" ?cell "NCNFET_L3_MC1" ?view "veriloga")
End netlisting Aug 2 13:26:14 2018
Im using IC6.7 and mmsim15.10
    Well, the first mistake is that it makes no sense to put the statistics block inside a subckt. Rather than creating  a spectreText view with that in (spectreText views are intended for structural designs really), you should create a text file (say monte.scs) with the contents of that subckt (without the subckt lines) and then include it in your simulation by Setup->Model Libraries in ADE.
    I have no idea why it would be complaining about shobhit/NCNFET_LC_MC1/veriloga when you've created a module called FET. Even if you created the cell called NCNFET_LC_MC1 but had called the module inside FET (not a good idea), I wouldn't have expected this error. I suspect there's some key bit of information you've omitted to mention - I don't even know why it would be looking at that view.
    Given the amount of time and effort it took last time to guess what you'd done wrong, I suggest you contact customer support so that somebody can take a look at what you've done rather than going back and forth all the time. I'm not sure I have the patience (sorry...)
  • Shobhitkareer
    Shobhitkareer over 8 years ago in reply to Andrew Beckett
    Thank you Andrew for your time, I'll contact customer service.
    Regards
    Shobhit
