  3. ADE-XL: possible to change binding of "Open Terminal" button...
  • Views 4067
ADE-XL: possible to change binding of "Open Terminal" button (launch xterm)?
dontpanic
dontpanic over 8 years ago
Hi! I recently switched from IC617 to ICADV12.2 (64b.500.5), and now when I press the "Open Terminal" button in ADE-XL (results tab), two strange things happen:
1) It doesn't open the terminal on the results directory corresponding to the tab from which I click the button. Instead, it takes me to my home folder.
2) It doesn't seem to run the "xterm" command as defined in my .cshrc, where it's aliased to "xterm -rv" to reverse the colors. Instead, it seems to execute a raw 'xterm' command. Since I have my shell colors (prompt, filetypes, etc) configured for a dark background, the opened xterm has very bad contrast and becomes very difficult to use.
In IC617 these problems wouldn't occur: the terminal was opened in the results directories, and it executed xterm as aliased in my .cshrc (thus with the reversed colors).
Is there a way I can change what the "Open Terminal" button executes in ICADV12.2, to modify it to what IC617 was running?
Thanks and regards, Jorge.
    Andrew Beckett over 8 years ago +1
    Hi Jorge, I don't believe it would ever have picked up an alias from your .cshrc because it always ran the command via system() which uses "sh" rather than "csh". Nothing has changed in this respect…
    Hi Jorge,
    I don't believe it would ever have picked up an alias from your .cshrc because it always ran the command via system() which uses "sh" rather than "csh". Nothing has changed in this respect for ages.
    I suspect that you may have had the cdsenv var set:
    adexl.gui openTerminalCommand
    (so try looking at envGetVal("adexl.gui" "openTerminalCommand") - if this isn't set, it simply launches "xterm -T 'testName' &" where testName is the name of the test. So you can change it yourself using:
    envSetVal("adexl.gui" "openTerminalCommand" 'string "xterm -rv")
    The working directory is set by ADE before it launches the xterm and then set back again afterwards. So you should be able to do:
    envSetVal("adexl.gui" "openTerminalCommand" 'string "pwd ; xterm -rv")
    (note you must put a space after pwd) and then it will print the working dir in the terminal that you launched virtuoso from before the xterm is launched. You might also want to type tracev(dirPath) in the CIW too before launching the terminal - then the directory should appear in the CIW that it's going to set it to.
  • dontpanic
    dontpanic over 8 years ago in reply to Andrew Beckett
    Thanks for your prompt reply, Andrew! I indeed had the variable set to just 'xterm'; switching to 'xterm -rv' did the trick Slight smile
    W.r.t. the directory issue, your debugging suggestion pointed the culprit: a definition in my shell configuration indeed had the effect of redirecting to my home upon login (actually, it automatically changed to a folder, launched a script which needs to be launched from that location (as it extracts some info from the path--not my idea! :P), and then switched back to home). I removed this from my .cshrc and now everything is back to normal.
    Thanks a million for your help! Have a great weekend!!! Smiley
