  3. VPS-L: vsaplot can't find "design.info" file
  • Views 557
KurtKimber1
KurtKimber1 over 8 years ago
I'm running VPS-L in batch mode (version IC617isr21).  I can run an EM analysis and get valid text results.  Then I run the "write_em_vsaplot_db" command (it runs without errors) and open "vsaplot" from the command line.  But I am unable to get vsaplot to load a results file -- it always errors out saying it can't find a "design.info" file.  I tried both psf and vavodb output formats.  Any suggestions?  Thanks
