  3. ADE-XL: force re-evaluation of Matlab script edited outside...
  • Views 15431
ADE-XL: force re-evaluation of Matlab script edited outside Virtuoso
dontpanic
dontpanic over 8 years ago
Hello! Is there a way to force ADE-XL to re-evaluate Matlab scripts? I always edit my scripts outside Virtuoso, and when I press the re-evaluate button in ADE-XL nothing changes and I get the following message in the CIW:
"INFO (ADEXL-8013): Re-evaluation of the resuts for history 'Interactive.XX' is not required because there is no change in the outputs setup."
So far the only way I found around this is to save the script with a different name, manually changing the script name in ADE-XL, and then re-evaluating, which is cumbersome. I'd like to re-evaluate the script just by pressing the "re-evaluate" button, without needing to change the outputs setup manually... is this possible?
Thanks and regards, Jorge.
P.S. As I store and edit the scripts from a centralized location in my filesystem, I have the following setting in my .cdsenv:
adexl.gui copyMeasurementScripts boolean nil
    Andrew Beckett over 8 years ago +1
    Hi Jorge, I think the only way to do this is probably to edit the script via the Edit button in the ADE outputs (the E button) - you may have to add a blank line or something like that. The alternative…
    Hi Jorge,
    I think the only way to do this is probably to edit the script via the Edit button in the ADE outputs (the E button) - you may have to add a blank line or something like that. The alternative is to use the drop-down next to the re-evaluate icon and change it to "Full". This will re-evaluate everything regardless of whether it's deemed to have changed.
  • dontpanic
    dontpanic over 8 years ago in reply to Andrew Beckett
    OK, thanks Andrew! (I was going crazy trying to figure out if some variable can control this...)
