  3. How do you generate a layout from schematic in Virtuoso...
  • Views 21964
How do you generate a layout from schematic in Virtuoso IC 6.1.5?
ernie123
ernie123 over 8 years ago
I know how to generate a layout from schematic in icfb (IC 5.1) using the Tools -> Design Synthesis menu in the Schematics XL window.
Unfortunately this menu does not seem to exist in the newer version of Schematics XL (IC 6.1.5), and I cannot find any explanation on how to do this after searching online (all tutorials I found talk about the old version).
Can anyone help?
Thank you
    You didn't say which version you're using now, but most likely it's Launch->Layout XL (rather then Tools->Design Synthesis->Layout XL as it was in the IC5141 release - which is pretty old - it came out 14 years ago...)
  • ernie123
    ernie123 over 8 years ago in reply to Andrew Beckett
    Sorry I meant version IC 6.1.5 (I wrote it in the title but I should have probably also written it in the question details as well).
    Andrew Beckett over 8 years ago in reply to ernie123
    Er, whoops. I clearly need a holiday - didn't see that. My answer is correct though for IC6.1.5 as well as later versions.
