  3. PVS-QRC: use of extracted Spice netlist with Spectre?
  • Views 19690
dontpanic
dontpanic over 7 years ago
Hi! We are trying to switch to PVS-QRC for our extractions in 16nm TSMC, but we're having a hard time configuring the flow to generate "av_extracted" views. As as workaround, we would like to use instead the "Spice" netlist created by QRC. However, it seems it's not even in Spectre syntax. I was wondering: what would be the most straightforward way of using the QRC Spice netlist for postlayout simulation? I remember in the past having imported netlists into Cadence, and the process was a bit lengthly, and definitely user-error prone. Is there an easy way to use these netlists?
Thanks and regards, Jorge.
  • Saloni Chhabra
    Saloni Chhabra over 7 years ago
    Hi Jorge,
    You are right that QRC generated 'Spice' netlist is as the name suggests 'spice' syntax, but not Spectre syntax. You can create a cell view type called 'Spice' in Virtuoso (just like you create a new schematic), and copy-paste the contents of this extracted spice netlist in there. Remember to use the SUBCKT header generated automatically by Virtuoso, and not what is in the netlist. Then, you can use this 'spiceText' view in simulations using hierarchy editor.
    Saloni
    • Vote Up +2 Vote Down
  • dontpanic
    dontpanic over 7 years ago in reply to Saloni Chhabra
    Thank you so much for your reply, Saloni; your proposed solution works fine. Just one question: when I edit the spiceText view I get the error below. Do you know what could be the problem? For now I am doing all these experiments using the libraries and the setup of the "Quantus QRC UI 001: Working with the Setup Tab" RAK.
  • Saloni Chhabra
    Saloni Chhabra over 7 years ago in reply to dontpanic
    Hi Jorge,
    What other views does this cell have? It seems that there is a verilog/verilogAMS/systemVerilog view which needs INCISIVE or XCELIUM (Cadence's digital/mixed-signal simulator) to be installed, so the view can be compiled. This is triggered even when you check & save the spiceText view. So, if you add this simulator to your installation path, this error should go away. Or, you can remove the views that you don't intend to work with.
    Even with this error, your spiceText view should still work..
    Saloni
  • dontpanic
    Hi Saloni. Indeed, adding XCELIUM to my startup setup took care of the error (and yes, the extracted view seems to work fine).
    Thanks so much for your help!
    Cheers, Jorge.
  • Dimitris Ant
    Dimitris Ant over 6 years ago in reply to Saloni Chhabra
    Hi saloni, I have the same problem. Let's say I have a cellview named inverter. I have the schematic view, the layout view and the extracted spice netlist. Then I should create a cellview inverter with view = Spice and copy paste everything form the extracted netlist except SUBCKT. and END. commands.  Should I  also create a symbol for my new cellview so I can use it in a new test bench?
    Andrew Beckett over 6 years ago in reply to Dimitris Ant
    This isn't really the same issue and under the forum guidelines you should have posted a new post.
    You can create a spiceText view, sure, but you wouldn't remove the .SUBCKT and .ENDS statements because otherwise it won't know what the pins of the block are. It will then prompt you to make a symbol (and can use the pin information in the .SUBCKT line to generate the list of pin names).
