  3. Multiple Via Cut Spacing for same ViaDefName
  • Subscribers 133
  • Views 2436
FormerMember
FormerMember over 7 years ago
We have a DRC rule that states that the Via Spacing must be larger if the Via Array Width or Height goes beyond a specific value.
Is there a way to define a via cut spacing value, within the techFile:viaDefs section, to be a larger value IF the number of cuts exceeds a specific number?
Similar to spacingTables:minOppExtension where the layer extension over a via can be a different value when the width of a metal path is larger?
Terry
