  3. Layout editor: change the highlight color of selected shapes...
  • Views 18848
Layout editor: change the highlight color of selected shapes?
dontpanic
dontpanic over 7 years ago
Hi! Is it possible to change the color used to highlight the shapes selected in a layout? My setup currently uses white, but I'd like something with more contrast like yellow or red.
I searched for keys on modifying the .Xdefaults file, but found nothing regarding this property. Can this be accomplished?
Thanks and regards, Jorge.
    Andrew Beckett over 7 years ago +1
    It's the color of the packet associated with the hiliite/drawing layer-purpose the technology you're using. You can change that using the Display Resource Editor. These reserved layer purpose pair combinations…
    These reserved layer purpose pair combinations are covered in the techPurposes section of the Virtuoso Technology Data ASCII Files Reference manual - it describes what they're used for.
  • dontpanic
    dontpanic over 7 years ago in reply to Andrew Beckett
    Found them! Thanks so much, Andrew!
