  3. QRC: how to avoid empty .SUBCKT (re-)definitions in the...
  • Views 6262
QRC: how to avoid empty .SUBCKT (re-)definitions in the extracted netlist?
dontpanic
dontpanic over 7 years ago
Hi! I am getting simulation errors when trying to use the extracted netlists produced by QRC, because they contain redundant (and empty) definitions for some components. For instance, in a minimalistic cell with a MOM cap I get in the extracted netlist the following definition:
.SUBCKT cfmom_2t_p80 PLUS MINUS
.ENDS
As a result, spectre complains when trying to use the extracted netlist view in a testbench:
ERROR (SFE-3263): "path/to/extracted/netlist/cellview/spice.spc": The subckt 'cfmom_2t_p80' is being redefined. Previously, it was defined in line XYZ of `/path/to/pdk/model/card.scs'. Remove or rename either definition.
How can I prevent these empty definitions from being included in the extracted netlists? If I edit the netlist and comment them the simulation proceeds and the results seem to make sense (i.e. the explicit (intended) MOM cap is instantiated along with the extracted parasitics; notice I don't want the MOM cap to be flattened--I want it to be recognized and instantiated so as to use its pdk model).
Thanks and regards, Jorge.
  • Saloni Chhabra
    Saloni Chhabra over 7 years ago +1
    Hi Jorge, You need an additional argument in your extraction command file. output_db - suppress_empty_subckts true Regards, Saloni
  • Saloni Chhabra
    Hi Jorge,
    output_db -suppress_empty_subckts true
    Saloni
  • dontpanic
    dontpanic over 7 years ago in reply to Saloni Chhabra
    Thanks for your reply, Saloni. I tried using a command file with the contents:
    output_db -type extracted_view -suppress_empty_subckts true
    and running and "extracted view" extraction but the spice netlist (the extview.tmp file under the svdb directory) still includes the empty subcircuit definition. If I use a file with these contents:
    output_db -type spice -suppress_empty_subckts true
    then the produced netlist doesn't include the empty subcircuits, but then I'd need to run QRC 2 times to also get also an extracted view. Do you think it would be possible to get the empty subcircuit suppression in the extview.tmp netlist when doing "extracted view"  extractions?
  • Saloni Chhabra
    Saloni Chhabra over 7 years ago in reply to dontpanic
    Hi Jorge,
    I don't understand how you are running the flow..
    What output format are you generating from QRC - spice or extracted view? If it's extracted view, then 'supress_empty_subckt' isn't a supported argument. What are you doing with extview.tmp? It is an intermediate file generated by QRC and isn't intended to be used by the user directly for simulations. extracted view should be specified in the config view (hierarchy editor) for the DUT, and then Spectre will netlist it.
    If you are importing a spice netlist into Virtuoso (using spiceText view), then you will have to generate a spice output from QRC which should allow you to suppress empty subckts.
    Saloni
  • dontpanic
    I am following the article "How to output both an av_extracted view and SPICE netlist in a single Quantus QRC run?". I am trying to debug extracted-view-generation issues in our 16nm flow, so, in this particular case, it would be really useful to have both the netlist and the extracted view generated in a single run. We are trying to migrate from Calibre xRC to QRC, but the generation of correct extracted views is so far probing very challenging.
  • Saloni Chhabra
    Okay, apparently, you've bumped into a situation where spice output format and extview.tmp cannot be made equivalent, so you'll have to comment the subckt's if you wish to use extview.tmp.
    Also, I'd suggest you contact Cadence customer support for getting some dedicated support on extracted view generation issues.
    Saloni
  • dontpanic
    OK Saloni, thanks anyway!
