  3. Is assura_tech.lib file set correctly?
  • Views 15309
AlexGo
AlexGo over 7 years ago
We installed a new PDK, but i found that assura_tech.lib file contains path to the previous PDK.
Does it mean that the new PDK was installed incorrectly or setting the assura_tech.lib file is not a part of PDK installation?
Is there some document in PDK when correct content of the assura_tech.lib file is described?
    This will depend upon how the PDK was created - it's not something that can be answered generically, as it's up to the PDK provider to set this up as they see fit. There might be a document in the PDK, but that too is up to how the PDK provider defined things - there's no standard structure for a PDK which enforces you to describe anything in a document or place such a document in a consistent place.
    Best would be to contact the foundry that provided the PDK.
  • AlexGo
    AlexGo over 7 years ago in reply to Andrew Beckett
    I see. Thank you very much.
