  3. ADEXL: automaticaly include extracted view
  • Views 17470
kwsgk
kwsgk over 7 years ago
Hi all.
I'm using ADEXL with spectre simulation with Extracted view Created by QRC.
Simulation work well, but I have a problem that it consumes much file size.
One of the reason is input.scs, it involve netlist of extracted view.
For some corner condition simulation or montecarlo, it makes a lot of input.scs, each of them
involve extracted view(~300MB), total file size become very large. But all of extracted view is same.
Are there any way to shrink input.scs size automatically?
I know that include netlist and replace cell to black box cell avoide this problem, but converting extracted view to netlist one by one and make those cell manually
are time consuming and cause typo or some mistake. I'm glad if there are some setting to  treat them as include netlist automatically.
Best Regards
KAWAI
    Hi Kawai,
    You can use:
    envSetVal("adexl.simulation" "ignoreDesignChangesDuringRun" 'boolean t)
    in your .cdsinit (note, the CIW would be insufficient) or:
    adexl.simulation ignoreDesignChangesDuringRun boolean t
    in the ~/.cdsenv (typically this needs to be your home dir).
    This enables another setting which generates a single netlist for all points and then includes it in each individual run. The effect of ignoreDesignChangesDuringRun is to run netlisting up front, so be aware that this will lead to a delay before simulations start for big designs. Note that the individual setting singleNetlistForAllPoints is not recommended on its own - there are some issues with this which mean that the netlist can get messed up sometimes - so we recommend  you use the ignoreDesignChangesDuringRun setting instead which achieves the same thing.
    We have  new Extracted view format coming in EXT18.2 (out soon) and IC618 (due out October) which should also help significantly too.
  • kwsgk
    kwsgk over 7 years ago in reply to Andrew Beckett
    Thanks a lot, Andrew.
    I tried it and found it works well. Netlist become symbolic link and it can save our file size
    As you say, some delay occurs for netlisting them in the begining of simulation.
    It is acceptable, but I hope it will be reduced in future releace.
    Best Regards,
    kawai
  • DuyDong
    DuyDong over 5 years ago in reply to Andrew Beckett
    Just a follow up question. Would this setting work with Maestro?
    If not, how can we have the same setting for Maestro?
    Thanks and regards,
    Duy-Dong Pham
    ShawnLogan over 5 years ago in reply to DuyDong
    Dear Duy-Dong Pham,
    I am not Andrew and will certainly not pretend to have his depth of knowledge!!
    However, I do know that even though the syntax for many former ADE-XL settings contains the "adexl" prefix, maestro honors the same command. I did ask customer support at one time about this as it can be confusing. I was told too many customers were using the former ADE-XL setting syntax in their designs and the effort to change was considered excessive. Hence, Cadence decided to not update the syntax of the ADE-XL settings to one including the "maestro" prefix.
    The setting "adexl.simulation ignoreDesignChangesDuringRun boolean t" is  further confirmed to work in Assembler (with the exception of the "parameters" check-box in versions prior to IC6.1.8/ICADVM18.1 ISR15  as shown at URL:
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O3w00000ADokcEAD&pageName=ArticleContent
    and after ISR14 this issue is resolved...
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O3w00000AAlADEA1&pageName=ArticleContent
    If you are just modifying an existing netlist, in lieu of re-netlisitng, you could explore using a reference netlist.
    I hope this helps!
    Shawn
  • DuyDong
    DuyDong over 5 years ago in reply to ShawnLogan
    Dear Shawn,
    Thanks a lot for your detail reply!
    Duy-Dong
    Dear Duy-Dong,
    I am just glad it was helpful! Good luck!
    Shawn
