  3. avoiding ams re-gen and re-compile the netlist database
  • Views 16445
DavidLou
DavidLou over 7 years ago
hello exports,
I'm using ams to run cosim with both analog (schematic + veriloga) and digital (verilog) blocks. everytime I run it by ocean script, I see it re-generate netlist and then re-compile the design even nothing has been changed yet.
the log prompt and Ocean script as followed. any clue?
thanks,
David
   Recompiling... reason: file './cds_globals.vams' is newer than expected.
   expected: Mon Sep 10 18:05:29 2018
   actual: Mon Sep 10 18:06:11 2018
   irun: *W,FILOD: The file  ...../ams/cosim_config/netlist/spiceModels.scs is out of date, the exec amsspice will be re-invoked.
   file: ./cds_globals.vams
simulator( 'ams )
solver( 'Spectre )
;open the top schematic view so the simulator can find it in memory for "ocean -replay"
;use "ocean -restore " no longer need this
dbOpenCellViewByType( "lib" "top" "schematic" )
; for config based case
design( "lib" "top" "cosim_config" "r")
ocnAmsSetOSSNetlister()
resultsDir( result_dir )
connectRules("ConnRules_mid")
modelFile(
'("....._usage.scs" "tt_lib")
analysis('tran ?stop "1" ?errpreset "conservative" )
envOption(
'amsIEsList '((t "global" "" "1.8" "connectLib.CR_full_fast" "" "logic" "discipline=logic;" "Built-in"))
'builtinuser nil
temp( 27 )
run()
    David,
    For the same directory, the netlister should be incremental - so it may be it doesn't do too much actual netlisting (although the time may be in the netlist assembly if using UNL - although here you appear to be using the older OSS netlister). Similarly the compilation should actually be incremental - it will run irun again, but it doesn't necessarily recompile everything. There are options in ADE which control whether it does a clean of the simulation data, or does increment modes - but you don't have these in your script.
    Is there a good reason why you're using OSS rather than the newer UNL netlister?
    If you're seeing performance issues, please contact customer support.
  • DavidLou
    DavidLou over 7 years ago in reply to Andrew Beckett
    Thanks Andrew,
    since it's still kind of re-gen/re-compiling, plus there'll be database locked in running, so I think better to just keep the netlist in different directory for each sim as asked in other thread.
    the reason to still use OSS is for this: I have a multi-module verilog file which is self-contained with sub-blocks designed and instantiated for AMS cosim (e.g., top, sub1, sub2, sub3,...). I have a digital top cell view for that top block but not any sub-blocks. OSS would find and bind these sub-blocks happily but not UNL (even Hierarchy Editor can't find these sub-blocks). I'm hesitate to create too many more cell views simply for that, as I might keep adding more digital sub-blocks. Is there a way to solve this?
     thanks,
    David
