  3. Changing the number of series instances in a schematic
  • Replies 9
  • Views 28312
MoHas
MoHas over 8 years ago
Is there a way to parameterize the number of series instances in a schematic and be able to change that from the symbol parameters?
Mohammed
    Hi Mohammed,
    This will depend on whether it's supported by the specific component in the specific PDK you're using.
  • MoHas
    MoHas over 8 years ago in reply to Andrew Beckett
    It's not a PDK component. I'm having a schematic/symbol of a model of wire of unit length. And I want to be able to change the number of units when I instantiate that cell.
    Mohammed
    Andrew Beckett over 8 years ago in reply to MoHas
    So if this is for instantiation in VLS XL, you could add a CDF parameter to your component called s and then you can set it to whatever you want. VLS XL will then use this parameter to generate multiple instances in the layout, which are series connected. You can see which parameters are honoured for VLS XL by going to Options->Layout XL, going to the Parameters tab, and in the Schematic Parameter Names section changing the cyclic choice to Series-connected factor and seeing the available parameter names.
    If you want your model to honour that in simulation (if you have a simulation model) you'll need to reference the s parameter in your model too.
    Does that help?
    Andrew Beckett over 8 years ago in reply to Andrew Beckett
    By the way, it rather helps if you say what tools you're actually using, which version and so on - the Forum Guidelines (pinned post at the top of each forum) explain this. Otherwise there ends up being quite a bit of guesswork in what you're really asking...
    I may have incorrectly guessed in this case, or I may have got lucky?
  • MoHas
    I'm using Virtuoso6/123 and MMSIM/161. I will read the Forum Guidelines soon, I've just created the account this afternoon Slight smile
    I'm trying to do that for simulation purpose only, I don't have a layout. So I need this "s" parameter to generate a schematic/netlist with multiple instances connected in series.
    Is that possible?
    Well, you can do it by doing something like:
    You can't parameterise the bus widths though (this is 6 in series - and so you have 5 internal nodes). The only real way to do this is to build a schematic pcell for your block - there's no simple "just add a parameter" means of doing this.
    Even if you made it a schematic pcell, you wouldn't be able to sweep the number of series-connected devices anyway because that would require the netlist to be rebuilt for each parameter value. That's me guessing again that this was your motivation...
  • MoHas
    That's exactly what I want to do. I want to parameterise the number of series elements. The intention is not to do sweep but to be able to use this pcell multiple times without the need to edit the bus widths manually each time.
    Thanks, Mohammed
    Hi Mohammed,
    Here's an example of a schematic pcell for a series resistor. In essence it's a cell with a parameter "ns" (you'd need to add this to your CDF as a string parameter, with parseAsNum set to "yes" ideally) and then inside the code change what it is instantiating. Obviously you'll be creating a new cell here at a higher level than your current wire component, but hopefully you get the idea.
    /* respcell.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Apr 07, 2014
    Modified
    By
    Example of a series resistor pcell.
    Original version only contained connectivity - this one contains "graphics"
    too so that if you descend into the schematic you can probe nets.
    SCCS Info: @(#) respcell.il 04/07/14.11:02:22 1.2
    procedure(abCreateResPcell(libName cellName)
      let( (pcellId)
        unless( ddGetObj(libName)
          error("Couldn't open library %L" libName)
        pcellId =  pcDefinePCell(
          list( ddGetObj(libName) cellName "schematic" "schematic" )
          ; Default Parameters
            (ns "1")
          let(( pcCV masterCv instName instId netP netM numInsts y (resHeight 0.375)
            (wireLen 0.125) pinMaster pinFig wire lastCoord)
            pcCV = pcCellView
            ; open master cellviews
            masterCv = dbOpenCellViewByType( "analogLib" "res" "symbol" nil "r" )
            pinMaster=dbOpenCellViewByType("basic" "iopin" "symbol")
            numInsts=atoi(ns)
            when(numInsts<1 numInsts=1)
            ; Create nets and terminals
            netP=dbMakeNet(pcCV "PLUS")
            netM=dbMakeNet(pcCV "MINUS")
            dbCreateTerm(netP "PLUS" "inputOutput")
            dbCreateTerm(netM "MINUS" "inputOutput")
            y=0
            pinFig=dbCreateInst(pcCV pinMaster "" 0:y "R0")
            dbCreatePin(netP pinFig)
            lastCoord=0:y
            for(inst 1 numInsts
              ; Create the nets connected to either side
              if(inst==1 then
              else
                netP=dbMakeNet(pcCV sprintf(nil "net%d" inst-1))
              ) ; if
              if(inst==numInsts then
              else
                netM=dbMakeNet(pcCV sprintf(nil "net%d" inst))
              sprintf(instName "R%d" inst)
              y=y-wireLen
              instId = dbCreateInst( pcCV masterCv instName (0:y) "R0" )
              dbCreateProp(instId "r" "string" "pPar(\"r\")/pPar(\"ns\")")
              ; Connect up the instance
              dbCreateInstTerm(netP instId dbFindTermByName(masterCv "PLUS"))
              dbCreateInstTerm(netM instId dbFindTermByName(masterCv "MINUS"))
              wire=dbCreateLine(pcCV list("wire" "drawing") list(lastCoord 0:y))
              dbAddFigToNet(wire netP)
              y=y-resHeight
              lastCoord=0:y
            y=y-wireLen
            dbCreatePin(netM pinFig)
            dbAddFigToNet(wire netM)
            dbSetConnCurrent(pcCV)
            dbClose( masterCv )
            ;; Always return true
            t
          ) ; ** let **
        ; not sure if below is really necessary
        dbSave(pcellId)
        dbClose( pcellId )
      ) ; ** let **
  • MoHas
    Perfect! I will give it a go.
    Many thanks!
    Mohammed
