  3. usim_trim to change block parameter multiplicity (m)
  • Replies 7
  • Views 16807
KOTB
KOTB over 7 years ago
To change a parameter in transistor, capacitance or resistor without touching the netlist, we can use for example :usim_trim instance=x1.x2.cap5 value=3f
What if I want to change the multiplicity factor " m" of an instance x1.x2.x3 from 1 to 4 for example ? It must exist a command :  usim_trim instance=x1.x2.x3 m=4  ?
kotb
    usim_trim can only be used with a small set of parameters, as documented.
    You could just use an alter instead:
    trim1 alter dev=m1 param=m value=4
    (the first word is a unique name to distinguish it from any other alter statements).
  • KOTB
    KOTB over 7 years ago in reply to Andrew Beckett
    Thanks Andrew,
    it is still not clear for me what is the dev=m1
    let's say my instance in netlist is :
    XSEG\<7\>  (sl\<0\>  bl\<0\> 0 vdd)  SEG_RC1X
    I want to add a multiplicity parameter of m=4 without touching the netlist. can I use the alter option directly OR the instance in netlist must already have a parameter m:
    (XSEG\<7\> (sl\<0\>  bl\<0\> 0 vdd) SEG_RC1X  m=m1) ?
    trim1 alter param=m1 value=4
    Kotb
    Andrew Beckett over 7 years ago in reply to KOTB
    Yes, this still works. You do need to put:
    trim1 alter dev=XSEG\<7\> param=m value=4
    The dev is the instance name. You can change the m-factor on a hierarchical instance, and will then apply m to everything within it (multiplying any existing m-factors on those lower level blocks by the m-factor on the instance).
    You can add:
    outPar info what=output where=file
    into the netlist, and then you can see the m-factor on each of the lower level effective parameters (it will write a file called netlistSuffix.info.output into the working dir with the information for the output parameters of each device).
    Andrew Beckett over 7 years ago in reply to Andrew Beckett
    Sorry, forgot to say that this can be done even if the instance does not already have m on it.
  • KOTB
    Thanks Andrew,
    I used this command line  :trim1 alter dev=X8SEG\<0\>.XSEG\<7\> param=m value=4
    and I have this ERROR:
    `trim1': Sweeping the parameters of a subcircuit instance (`XSEG<7>') is currently not supported by `dev' parameter. Please use `sub' parameter instead.
    So, I replaced 'dev' by 'sub', as said in the ERROR and now it works with no problem.
    Thanks again, I am really grateful for your continuous support and smart solutions.
    kotb
  • KOTB
    When I use   trim1 alter sub=X8SEG\<0\>.XSEG\<7\> param=m value=4  , I have no warning in the log file and the command line is taken in consideration because when I look into netlistSuffix.info.output, I find that all devices in the instance X8SEG\<0\>.XSEG\<7\>  have a multiplicity value meff=4
    But when I see simulation results, nothing changes even I put param=m value=160 , just to have a huge load. the value of m is always equal to the initial value in the netlist which is m=1.
    I find your answer in some problem which looks a little bit similar in this link
    https://community.cadence.com/cadence_technology_forums/f/custom-ic-design/23118/spectre-parameters-in-alter-statement-not-effecting-digital-vector-file-stimuli
    Do you think it is the same problem of spectre control mode (interactive or batch)? If so, could you please tell me what should I change to tell spectre that I am using batch mode ?
    kotb
    If this is an issue, please contact customer support. I don't think there's anything in the post you referenced which is relevant here, and the workaround of using controlMode batch isn't going to help - if this happens in the first simulation you run, it's not going to matter - plus Ultrasim is not run in interactive mode.
