  3. ADE L netlister to stop at cell name match rather than view...
  • Subscribers 129
  • Views 13862
ADE L netlister to stop at cell name match rather than view name match
SatendraMaurya
SatendraMaurya over 7 years ago
I have a design with standard cell. For the standard cells I only have layout and symbol. When I try the ADE XL netlister, it could not descend into these standard cell since there is no schematic for them. If I put the symbol in the switch and stop view lists , it does not show the standard cell interface.
Satendra
    Hi Satendra,
    Is there any CDF for your standard cells? You'd also need the spectre simulation information in the CDF so that it knows what order to write out the terminals (presumably to match an external definition of the standard cells).
    There is no "ADE XL" netlister - presumably you're talking about the spectre netlister? Or is it the netlister for some other simulator?
  • SatendraMaurya
    SatendraMaurya over 7 years ago in reply to Andrew Beckett
    Thanks for the quick reply. Yes the issue was with the cdf info. I updated it and now able to get it working fine.
    Satendra
