  3. failure with using amsd block
  • Views 19706
fatcat1206
fatcat1206 over 7 years ago
Hi All
I am trying out to use amsd block to configure some cells to be bound to a spice netlist.
inside the amscf.scs file, I am writing some thing like:
include "analog_top.scs"                      //hierarchical netlist for whole analog design
include "modelfile.scs" section=tt       //model files and section selection
include "analogControl.scs"                 //simulator and analysis settings
amsd{
  portmap subckt=ana_top porttype=name autobus=yes
  config cell=ana_top use=spice
  ie vsup=1.5
My intentions is to use the schematic for whole analog top in the DUT.
Unfortunately, the end results is not good.
The ana_top cell has been resolved to "worklib.ana_top:spice-skeleton" as shown in the log file, with "-libverbose" option in irun.
But such "spice-skeleton" view contains no real content, just bunch of parameters.
And according to the simulation results/speed, it shows that the ana_top cell is indeed empty.
Does someone have clue about where  may go wrong?
Best Regards
Yi
  • Nasser Arif
    Nasser Arif over 7 years ago
    Hi Yi,
    tools internally create the spice-skeleton file, you shouldn't care about it.
    it is not clear by statement "Unfortunately, the end results is not good", could you please explain.
    Nasser
  • fatcat1206
    fatcat1206 over 7 years ago in reply to Nasser Arif
    Hi Nasser
    Thank you for replying.
    The problem I am facing is that the ana_top cell seems to be empty.
    When I use the "source_browser" to open the snapshot, the content of the the "ana_top" cell is just pin definition, parameter definition (it seems that the parameter is derived from the model file)
    And there is no internal net /sub-blocks when I check with the "Design Browser"
    But no real content for the design.
    I have tried to run the simulation, it finishes super fast (run 1ms is finished within a second), even faster then the RTL simulation, which is not normal.
    And no activities on the ana_top outputs.
    And when I look at the log file again, I see two message for resolved instance, like:
    Resolved design unit 'ana_top' at 'TB.dut@DUT<module>.acore' to spice subckt.
    Resolved design unit 'ana_top' at 'TB.dut@DUT<module>.acore' to 'worklib.ana_top:spice_skeleton'.
    Is this double resolving a normal behavior?
    I am suspecting the binding to spice-subckt is overwritten by the second binding spice_skeleton.
    Best Regards
    Yi
  • fatcat1206
    fatcat1206 over 7 years ago in reply to fatcat1206
    Some follow up:
    My colleague goes through the flow with me again, and comparing with her successful one:
    • The amsd flow looks fine
      • port-bindings are done correctly
      • The skeleton interface is created and used in the simulation.
      • source-code of the spice-skeleton looks the same in both
      • In the simulation results, the interface and connect module around it are observed
    But we have no clue, why the spice netlist is not in the simulation in the end.
    Hope some one can point it out where I miss in the irun setup.
    Best Regards
    Yi
  • Saloni Chhabra
    Saloni Chhabra over 7 years ago in reply to fatcat1206
    Hi Yi,
    Your setup looks correct. Have you got any save statements in analogControl.scs, or are you providing a probe.tcl file to irun? With the correct save/probe statements, you should be able to see the content inside your analog block as well. It is possible that your analog block isn't getting the correct inputs (e.g. supplies) which is why the simulation runs fast.
    Saloni
  • Saloni Chhabra
    Saloni Chhabra over 7 years ago in reply to Saloni Chhabra
    I missed an important point. Please check your simulation log (irun.log) to see what circuit inventory says. By looking at the number of devices and nodes in the transistor-level circuit, hopefully you will get an idea whether the correct ana_top represenation has been used or not.
    An example:
    Circuit inventory:
                  nodes 8
                  bsim4 2
         bsource_2b273e 2
    connectLib__Bidir_2__module__0x10000001_behavioral 3
  • fatcat1206
    fatcat1206 over 7 years ago in reply to Saloni Chhabra
    Hi Saloni
    Thanks a lot, the circuit inventory is really helpful.
    I see such number in the log file:
    Circuit inventory:
    nodes 23917
    bjt 2
    bsim4 11290
    bsource_04fdc6 112
    bsource_3166b9 208
    bsource_a6a55c 170
    bsource_cb93ba 16
    So the spice netlist is indeed in the simulation.
    Then I can focus on the debugging, might some connect module need some special setup.
    I will try to add probe.tcl file to have some inside of the sub-blocks.
    It's my first time to setup amsd, and dive into it.
     Best Regards
    Yi
