  3. how to sweep an equation which is formed using variables...
  • Views 15794
how to sweep an equation which is formed using variables?
CKAITHANYA
CKAITHANYA over 7 years ago
Hi
I created an inverter with pmos and nmos and declared their widths as variables (Wp, Wn) by keeping the lengths constant. Now I want to plot VOUT vs  VIN  for different values of Wp/Wn ratio instead of doing parametric for Wp and Wn separately. I mean there is any way for directly sweeping the equation formed by variables.
    You could define your variable Wp to be (say) ratio*Wn and then sweep ratio for a fixed Wn. Does that do what you want? That seems fairly obvious, so maybe I've not understood your question.
  • CKAITHANYA
    Yeah, I agree with your approach but in case if I don't want to fix any one of the variables and sweep the ratio. Is there anyway?
    Its like if I have three variables x,y,z and there is a relation between them x*y+z =r (let's say). Now instead sweeping for all the three variables is there any way in which I sweep "r"? so that I can get random combinations of x,y,z
    Andrew Beckett over 7 years ago in reply to CKAITHANYA
    No. This is not possible and I can't see it would make any sense either given that there would be no constraints on any of the variables - there are multiple solutions to that equation if you are just sweeping the result.
