  3. Printing to a file using fprintf
  • Views 15597
ajitg
ajitg over 7 years ago
I have a simulation for generating MOS transistor data using a 4 nested sweeps (VGS, L, VDS, VSB) for a 4-terminal NMOS device. I am able to setup the simulation and run it with all working OK. However, I am trying to get the results into a .csv or .dat file in a clean manner.
I am using IC617 with Spectre version 16.1.0.479.isr9.
I know this question was asked before over here https://community.cadence.com/cadence_technology_forums/f/custom-ic-skill/33105/parametric-analysis  but the solution to use MATLAB is not something I can do at the current time. I will have to stick with using OCEAN or using a manual click and save as .csv
My setup is such that the VGS sweep is configured in ADE XL analysis window and the other sweeps are configured within the parametric analysis window (from top to bottom VSB,VDS,l)
My initial way to print the data into a .csv file was to use ocnPrint() which I know works best for plotting waveform data:
selectResult('dc)selectResult('dc)ocnPrint(?output "~/MOS_sweep/gm.csv" ?numberNotation 'scientific getData("M0:gm"))
This results in a .csv file that is a little cumbersome to read in MATLAB, in that it has blocks of 2-D data (with VGS and l as the sweep variables) and then multiple such blocks for swept values of VDS and VSB.
By right clicking the parameter under the 'dc folder in Results Browser and creating a table, however the data is listed a 2-D data which is much more convenient to me. My question is how to invoke the table and save that as a .csv file from OCEAN?
AG
    There is no OCEAN support for invoking the table and saving the contents as CSV, unfortunately.
    Perhaps you can write a perl script to reformat the data from ocnPrint? Potentially you could write code to process the swept data and output in whatever format you want, but that may not be that easy. Perhaps you could use the code in this post?
