  3. Evaluate expression only after all parametric simulations...
  • Views 17432
Evaluate expression only after all parametric simulations are finished
Emiel
Emiel over 7 years ago
I'm using ADE Assembler (IC6.1.7-64b.500.17).
I have a parameterized desgin variable. I have an expression for the noise and for a certain current. The noise and currents are both calculated/evaluated correctly for the swept design variable and show up in the results.
When I use the calculator and use the waveVsWave to plot the noise vs current, I get the plot that I'm after.
However, when I add that expression from the calculator to the ADE outputs, assembler tries to evaluate that expression for each single design variable value when a simulation is performed.
Resulting in an 'eval err' in the output (because it tries to plot a single point) and not yielding the wanted (noise vs current) plot after the simulation is finished.
How can I evaluate/plot an expression only when all the simulations (for the set of design variables) are finished?
Emiel
    Hi Emiel,
    Given the limited information you've provided (you didn't say what you've swept, what the expression is - so it's quite hard to picture exactly what the setup is), I suspect you need to change the exprType field for the output expression to be "sweeps" rather than "point" so that the expression is evaluated as a "measurement across sweeps" rather than a per-point expression.
  • Emiel
    Emiel over 7 years ago in reply to Andrew Beckett
    I swept a design variable (used in several CDF fields in multiple components).
    Changing the EvalType to sweeps solves indeed the problem that the expression is evaluated for each single value in the sweep.
    I now get the error "Second argument is not a valid wave/familyWave" for that expression in the CIW.
    This is the expression:
    waveVsWave(?x (- IDC("/V0/PLUS")) ?y ymax(sqrt(iinteg((getData("/out" ?result "noise")**2))) ?overall t))
    (Manually plotting this after the simulation (via the calculator and removing the ' ?overall t' part) still yields the plot I wanted.)
